low'n blown wrote:
gaf, the rebels look great, had them modified to fit blown and restored. Have a small problem though, the other rims I am using are 3 piece and the actual inside area of the rim is bigger. My discs are 10.5 inch diameter and the calliper scrapes on the inside of the rebel rims. I am having them machined to remove a mm from the inside and I will have to remove about 1.5 mm removed from the calliper. After all that they should fit. I am using them as track wheels but the slicks may see a few outings on the road.
Any pic's of them on a Mini they would look very interesting
I bet you were hopping they would just slide on once the wheel nut holes were re done.
Nice score Brad on the cubby I saw the clubby this also yesturday morning on Ebay and considered it. Your other half will love it for te daily drive, I'm sure Bugger Ay
