thansk miniman but not sure I'll be doing any of this stuff meself ... .will be entrusting most of this to who ever does the machining/build....
BALLISTIC wrote:
Skender do you have rods and crank for this block??
If you want the block measured, ive got snap gauges.
G'day Scott, I plan on using the rods and crank out of the 1100s block I have .... apparently this means I have to get +30" crank thrusts??
I like to get mine around .010-.020" deck height...
hmmmm sounds interesting ..... tell me more? I take it you mean positive clearance? I've heard a bit about this. Does this raise your compression?
