It is currently Thu Aug 14, 2025 6:01 pm
Post new topic Reply to topic  [ 66 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Fri Jan 09, 2009 10:35 am
Wombat wrote:
Simon I gather you had no problem with the flasher can driving the LED circuit? or did you change it to a low current draw electronic one?
you gather correctly David - an email is on it's way too
PostPosted: Fri Jan 09, 2009 10:44 am
i'll take two, they're brill!
tim.
PostPosted: Fri Jan 09, 2009 10:53 am
lol - OK, I'll get a quote on making a batch of boards and cost them out :wink:
 Post subject: Great idea
PostPosted: Fri Jan 09, 2009 12:59 pm
Tomboss Breweros
I think any lighting improvement to a mini is an excelent idea but the department of transport doesn't think so. So if anyone has LED lights, and your car is being inspected, put in normal globes cos theyre probably not ADR approved, an inspector whos had a bad day could make yours worse.
PostPosted: Fri Jan 09, 2009 1:36 pm
Fair enough comment Tombo but enclosed light like the front parker/indicators are hardly going to attract close attention unless they don't work - afterall they don't check them in the dark do they which is when they really have to perform
PostPosted: Fri Jan 09, 2009 1:45 pm
that's true, but when some silly bimbo crashes into you, and even though you had your indicator on she swears you didn't then they check your indicators and find non-ADR approved globes..... guess who would be in the crapper.... though I bet I could argue my way around that and say my car is pre-ADR anyway
so Simon, when you've got them made, can I have a pair :D
PostPosted: Fri Jan 09, 2009 4:21 pm
looks like a way to make back that 5K you said the forum cost you in lost earnings last year Simon!
btw - put me down for two too
'62 Morris 850 (Marion)
'69 Vanden Plas Princess 1300
'71 Wolseley 1300
'74 Austin 1300 Countryman
'94 XJ6 Sport 3.2
'04 Rover 75 CDTi
PostPosted: Fri Jan 09, 2009 6:09 pm
I like the idea, I'll need two set's Simon. You may have to increase the fuse size. I found I was blowing the fuse when I connected my new trailer which had LCD lights.
:idea:
 Post subject: ADR.
PostPosted: Fri Jan 09, 2009 6:12 pm
I Think the ADRs only applies to lenses and not the actual Bulb type. As long as the wattage is an equivalent to 21Watts for indicators and Stop lights and 5 Watts for tail lights and parkers..
"Let us remove your "SHORTS"
PostPosted: Fri Jan 09, 2009 6:50 pm
HJM wrote:
I like the idea, I'll have some too Simon. You may have to increase the fuse size. I found I was blowing the fuse when I connected my new trailer which had LCD lights.
:idea:
nah, that's just because you had extra load, and probably poor connections - LEDs use a lot less current than normal globes
PostPosted: Fri Jan 09, 2009 7:05 pm
Give Ash some flowers Nick .
If you do go ahead with it simon, i'll buy a set :wink:
PostPosted: Fri Jan 09, 2009 7:30 pm
I'm in for two sets mate.
 Post subject: Re: ADR.
PostPosted: Fri Jan 09, 2009 8:10 pm
Thats easy just put a dirty big 20 watt 7.5 ohm resistor in parallel with the LED's :lol:
PostPosted: Sat Jan 10, 2009 12:04 am
Forum Graffiti
+1 for a set
PostPosted: Sat Jan 10, 2009 11:23 am
hey look great Simon , simple question though , do LED's need to be set a certain way for the polarity of the power or are they like a regular bulb which will work with an alternator or a generator ?
Users browsing this forum: Majestic-12 [Bot] and 256 guests
