It is currently Fri Aug 22, 2025 12:02 pm
PostPosted: Fri Feb 06, 2009 8:42 am
that supercrap degreaser is the best i use it on everything it's so cheap to.
Cheers Dan
PostPosted: Fri Feb 06, 2009 9:52 pm
hi steve ,i use 2,3rds kero and 1,3rd diesel in mine.
First you get the money,then you get the power,then you get the Mini.
PostPosted: Fri Feb 06, 2009 11:04 pm
Lubrimax do a parts cleaning fluid, can be purchased in a 20litre drum, and apparently will not burn.
dryes ya hands n makes em go white... seems to ahve all the properties of diesel.
-Cam
PostPosted: Thu Feb 12, 2009 9:43 pm
We have a parts washer and a turbo wash at work. The stuff in the parts washer is a Shell product, can't remember the name though, but its basically just kero with an added ingredient. the stuff in the turbo wash is alkaline salts, which is dish washer powder.The temperature in our turbo wash is about 60c. At home I use kero to degrease then the dish washer to remove the kero, only small light bits though. The company that sells/leases the industrial cleaning washers and solutions is called ERS they are nation wide.
TOO MANY MINIS AND NOT ENOUGH TIME
