It is currently Sun Jul 20, 2025 9:03 pm
PostPosted: Thu Mar 10, 2005 10:38 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
on the bottom of the carby jam there is a twisty turny thing for adjusting the mixture
makka
PostPosted: Thu Mar 10, 2005 10:39 am
makka
right underneath? what way does what?
PostPosted: Thu Mar 10, 2005 10:41 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
um it is hard to explain if ya know what i mean
makka
hehe probably shouldnt touch it then
PostPosted: Thu Mar 10, 2005 10:42 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
thats right it is easy to show but hard to explain
makka
PostPosted: Thu Mar 10, 2005 10:44 am
ok...i'll do some reading in the manual then :P
PostPosted: Thu Mar 10, 2005 10:59 am
The nut is on the jet tube assembly thingy - screw down is richer and screw up is leaner. Go by the manual and then wind it DOWN 1.5 flats and you will be in the ball park. You will then be able to do the finer adjustments to get her running like a trooper.
Yours, Aye
Rob Forsyth
Miniot!
Rob Forsyth
Miniot!!
PostPosted: Thu Mar 10, 2005 11:03 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
yeah but it is which way for up and which way for down that is the thing
makka
PostPosted: Thu Mar 10, 2005 11:17 am
makka....didn't you read his comment?
Thanks Rob!
PostPosted: Thu Mar 10, 2005 11:19 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
ok do you turn it left for richer or right for richer ............
that is what i am asking
PostPosted: Thu Mar 10, 2005 11:22 am
i read it as this...
Working with the carb in the car, screw the nut UPWARD (towards the sky) to make it leaner, DOWNWARD to make it richer :D
PostPosted: Thu Mar 10, 2005 1:00 pm
yeah but you cant tell cos you cant see the nut while you're doing it
i believe its clockwise from above the carburettor to richen the mixture, which viewed from below the carburettor is loosening the nut and turning anti clockwise..
this moves the needle down and more fuel can flow over it.
PostPosted: Thu Mar 10, 2005 2:13 pm
J_A_M wrote:
Gadgets mini wrote:
if it is leaning out I need to richen the mix (turning clockwise ) Right ?
Turning what? What's the adjustment and where is it?
Hmm HS4 if my memory serves me correctly it is a screw recessed on the side of the carby and unlike the normal SU you screw it in to richen and out to lean.
Good luck with it I never got mine right I know a lot of people have but mine was always lean in the high rev range and it seemed to have all the right jets and needles.
Regards Miniclubman
My Nissan is Just Transport But my MINI is FUN !!
PostPosted: Thu Mar 10, 2005 7:09 pm
Regards Miniclubman
The HS2 and HS4 are the same with the adjustment nut, not sure about HS6/hif44 although I think the HS6 is the same.
Cheers Pete
PostPosted: Thu Mar 10, 2005 11:22 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
the hif 38 and 44 have it on the side they are the ones with the fuel bowl underneath
makka
and spaceboy understood me :P
makka
Users browsing this forum: Phil 850 and 65 guests
