It is currently Fri Jul 25, 2025 11:41 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Thu Mar 19, 2009 7:00 pm
measure from the lip of the fuel filler recess to the lower seam, by eye it looks like the seam is lower than it should be ?
PostPosted: Thu Mar 19, 2009 7:11 pm
Fuel filler lipe on a van is totaly differant to the commen Mini fuel filler even to the corners of each corner of the arch to a normal. Vans are differant but im sure the arches are location to the filler
PostPosted: Thu Mar 19, 2009 7:26 pm
Jim, I have absolutely no idea what you're trying to say
I was suggesting you measure your van, and I'll measure my traveller and we can compare
PostPosted: Thu Mar 19, 2009 7:41 pm
sorry I was measureing Marcia to Morris 22" from filler to Coener of wheel arch to bottom seam :wink:
PostPosted: Thu Mar 19, 2009 7:48 pm
Mine like that fit perfectly ,
PostPosted: Thu Mar 19, 2009 7:59 pm
NAV-MAN
I have the same plastic screw on flares for NAV as well and they sit fine.
Try installing them with the rear part lined up. it may take some effort to get it to sit properly
PostPosted: Thu Mar 19, 2009 8:05 pm
I think he's got the picture.... stop rubbing it in !
PostPosted: Thu Mar 19, 2009 8:09 pm
Mine fit perfectly..
PostPosted: Thu Mar 19, 2009 8:35 pm
yep also tried installing from the front and the rear but they both bollow at the top if pushed from the other side.
Cheers Simon...somthimg is out somewhere
PostPosted: Thu Mar 19, 2009 9:13 pm
I wouldn't be too concerned about it, a little bit of cutting to the flare and some fibreglass to fill the gap
PostPosted: Fri Mar 20, 2009 5:35 pm
I've got the same type on my Clubby van, and had no issues fitting them.
Watto :shock:
PostPosted: Fri Mar 20, 2009 6:25 pm
Have they been sitting in the sun or something to make them warp? Can you try heating them gently & seeing if they take the body line a bit better.
PostPosted: Fri Mar 20, 2009 6:41 pm
I'll give Jim the old RR one off my car, I replaced them for the new paint job but the shape is still fine. :wink:
PostPosted: Fri Mar 20, 2009 10:03 pm
I is a mookenik
vans looks so much nicer and meaner without flares...
PostPosted: Fri Mar 20, 2009 10:11 pm
NAV-MAN
And that has what to do with Gafmo's problem with fitting a flare to his van exactly? Don't get me wrong I like the 2 vans pictured. Just not relevent to this thread.
How's the flare drama going Gafmo?
