It is currently Fri Jul 18, 2025 11:54 pm
PostPosted: Fri Mar 27, 2009 10:48 pm
I like amp and voltmeters. A voltmeter will tell you you have a problem, but an ammeter will tell you in conjunction with the volt meter where the problem is while the engine is running.
Plenty of volts and charge current when running, but won't start in the morning = battery issue
Low volts + plenty of charge current = alternator issue
Low volts, no charge current = alternator issue
High volts (14v +) and plenty of charge current = alternator issue (which makes it an issue to your battery)
etc etc..
A voltmeter will tell you you have a problem, but you will already know this by the time you look at it (when the engine has started to stutter). An ammeter on its own won't tell you much either.
PostPosted: Fri Mar 27, 2009 11:21 pm
A voltmeter is the safest gauge for an amateur to fit.
An Amp meter is the most dangerous gauge for an amateur to fit.
Are you any good at fitting electrical stuff?
Yes = Amp gauge.
No = Volt gauge. :lol:
PostPosted: Fri Mar 27, 2009 11:45 pm
How about this?
PostPosted: Fri Mar 27, 2009 11:53 pm
blue_deluxe wrote:
How about this?
They don't work down here. :cry:
PostPosted: Sat Mar 28, 2009 12:02 am
Yes = Amp gauge.
That's a good point, solder your fittings and heatshrink the terminals. A nice easy wire installation with a professional finish will cause you no problems as a rule of thumb. If it looks good, and had no tight stretches, no sharp rubbing edges and clean joints at the ends then it will work well for many years.
It is difficult to position a ammeter such that you get a meaningful value from it. Placing it in series with the alternator will only ever give you a positive current. Putting it in series with the fuses will only give you a negative measurement. You have to create a bottleneck where all the power needs to flow in or out of the battery circuit to get a useful reading. Around the solenoid is a good place to think about designing this solution. You have to think very carefully before you start soldering...
PostPosted: Sat Mar 28, 2009 8:12 am
Slow-Po
Go an buy yourself a moke with no roof. It'll rain for 40 days and nights after that.
PostPosted: Sat Mar 28, 2009 8:15 am
I sold a Moke with no roof (or much else) to 1071 down past your way, so it should be raining already. :lol:
PostPosted: Sat Mar 28, 2009 9:24 am
This space for rent
Does anyone make inductive-loop-pickup automotive ammeters?
PostPosted: Sat Mar 28, 2009 9:32 am
Every instrument maker in the world makes at least one inductive loop ammeter, but these are only usable on AC circuits, not DC.
The method they use when measuring large DC currents is to use a shunt. The shunt is a short piece of copper which will cause a known voltage drop for every ampere which goes through it. eg. 1mV/A which means that a 10 amp current will produce 10mVolts across it, 20A = 20mVolts etc etc. These work well, but are a little cumbersome in an engine bay. But they use a shunt in the back of the ammeter gauge to drive a voltmeter movement.
PostPosted: Sat Mar 28, 2009 9:33 am
This space for rent
Duh, of course :roll: Haven't had my coffee this morning...
