It is currently Sat Jul 19, 2025 9:25 pm
PostPosted: Thu Mar 03, 2005 5:55 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
they hd them on cooper s's that looks like it may be a original coopers manifold
makka
PostPosted: Thu Mar 03, 2005 6:23 pm
yeh a cooper s i was told :)
PostPosted: Fri Mar 04, 2005 8:23 am
PCV Valve Positive Crankcase Ventilation
It allows air to circulate through the engine otherwise it would restrict the passage of oil.
/edit Sorry the breather does that
The PCV valve is there so that it takes positive air pressure to open the valve so that you can hook the ventilation up to your inlet manifold and not have a vacumn leak. Alternatively you can hook the pipe up to the back of your air filter. The one on my unregistered mini at home is not connected at the moment but it pours out quite a bit of smoke and stuff so maybe it is better to leave it connected ? so saying my carbie is running very rich so this may have something to do with it (unburnt fuel) . Weber with the wrong jets and I want do some more stuff to the motor before I get it jetted properly.
Roads need more corners
Last edited by fuzzy-hair-man on Fri Mar 04, 2005 11:36 am, edited 1 time in total.
 Post subject: Re: what is this clubman
PostPosted: Fri Mar 04, 2005 11:32 am
benjamin wrote:
when i looked up my chassis number for my clubman this is what it is Leyland mini EPAI 998 what is that model?? :? whats is EPAI
E?...PollutionAir Injection ? maybe?
lookin for another clubby
