It is currently Sat Aug 09, 2025 2:00 pm
what to use when replacing a gasket eg. water pump gasket
just the gasket, put a slither of oil on it to lube it up and make it nice and slick! 0%  0%  [ 0 ]
gasket and gasket goo on both sides 71%  71%  [ 27 ]
just gasket, if both pump and block are completely clear it is the right thing to do 5%  5%  [ 2 ]
just the gasket goo... 3%  3%  [ 1 ]
let a bunch of asparagras form an ultimate protective slime, completely imperveous to water and heat! 21%  21%  [ 8 ]
Total votes : 38
PostPosted: Fri May 08, 2009 7:14 pm
I use a product by Dow Corning called DC4 its a silicone insulating grease that we use on most of the gaskets on the aircraft engines. The mating surfaces MUST be clean and smooth but it keeps the gasket moist and flexible and when you need to dissasemble they come off easily. Just put a little on your finger and rub it in until the gasket has gone dark all the way around.
I also use it on the oil filter seal and never have problems removing them.
Gig
67 Deluxe - Red and white
69 Deluxe - Sugercane Grey
PostPosted: Fri May 08, 2009 7:15 pm
mattsmadmini wrote:
where does everyone get these things??? ive trolled the bunnings and auto stores most of the arvo...cant find any cept the peratex? stuff at supercrap.... anyone?
Loctite 515 is available from any bearing shop, Blackwoods, or other industrial suppliers.
Not Bling stores like Supercrap, Autobarn etc. But they `might' order it in. :wink:
PostPosted: Fri May 08, 2009 7:49 pm
Tomboss Breweros
Repco and Motor traders (Coventry) keep the good products on the shelf.
Hi temp red silicone is great too, stops leaks on mitsubishis.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Fri May 08, 2009 9:24 pm
Loctite products ~
Matt, Not far from you.
CEDRAY.
81-83 Silverwater Rd,
Silverwater, NSW 2128
Phone:(02) 9648 5666
They are general industrial suppliers. Great for the odd UNF bolt you need or nut.
They have all Loctitie products at a very competitive price.
Steve
"Boris" - '69 Cooper S Mk 2
PostPosted: Sat May 09, 2009 3:32 am
Milatsmadmini
cheers steve!
PostPosted: Sat May 09, 2009 6:34 am
Personally I use Three bond "rusty red" sealant.....you only need to use a very thin smear on both sides of the gasket. Awesome stuff!! Its available from Bursons.
PostPosted: Sat May 09, 2009 9:00 am
Loctite 515 Master Gasket is designed for metal to metal joints, it seals well with NO gasket.
I have built 2 boxes with no diff side cover gaskets (which are too damn thich these days) and no leaks. Good stuff- but expensive. $20+ for a small tube.
I've not had a box leak since I started using this stuff on all the gaskets years ago.
PostPosted: Sat May 09, 2009 9:14 am
Got to agree with Kev on this.
Loctite products may be a little more expensive, buy they work. Small price to pay at the end of the day if you have a leak and have to strip the engine / box down to fix..
Been using Master sealant at work for years. Never a problem.
