It is currently Fri Jul 25, 2025 1:32 am
PostPosted: Thu May 21, 2009 9:56 am
early were hydro
PostPosted: Thu May 21, 2009 10:00 am
Its all to do with colours. The early '70s ones were painted grey and grungy green and dirty white (with stains running down from the fuel cap), whereas the later ones were painted bright red or lime green or metallic colours (but usually yellow).
At least that's what it seemed like when I was a teenager.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Thu May 21, 2009 10:07 am
ginger ninja
ginger ninja
Timbo wrote:
Its all to do with colours. The early '70s ones were painted grey and grungy green and dirty white (with stains running down from the fuel cap), whereas the later ones were painted bright red or lime green or metallic colours (but usually yellow)(with stains running down from the fuel cap also included on these).
sports850 wrote:
PostPosted: Thu May 21, 2009 12:23 pm
did any of them have the english grill? Like on my new clubby?
This ones got hydrolastic, drums all round, rubber unis and i believe a 1098. Also has a column mounted ignition. The compliance plate says november 1972.
Is this just a mix of leyland parts? Or been messed around with at some point?
PostPosted: Thu May 21, 2009 1:18 pm
Sounds original but that grille is not. :wink:
PostPosted: Thu May 21, 2009 2:42 pm
Both My Leyland Mini and my current Mini S still have the speedo hole in the middle with a plate screwed on with four screws. Must have been cheaper than to reset the production line in the factory.
PostPosted: Thu May 21, 2009 5:25 pm
The hole was not just for the speedo. It was for the rotodip spit to run through the car.
PostPosted: Thu May 21, 2009 5:27 pm
swae85 wrote:
So just looking at the actual Mini Clubman which became the Leyland Mini S..
Center ignition > Steering Lock.
Low Back seats > Headrests > Tombstone seats.
1100cc > 998cc.
Remote change gearbox > Rodchange gearbox.
Rubber Unis > Pot joints
2 dial dash > 3 dial dash.
Steel wheels with hubcaps > Steel sports wheels + Flares.
Rotodip > Rust
Single circuit brakes > Dual circuit brakes.
Badges Mini Clubman > Leyland Mini S.
Blue engine paint > Black engine paint.
Manual pump windscreen washer > Electric washer > changed washer bottle.
Did all later (76-78ish) Leyland Mini's have 3 gauges? I thought only Mini S' had the three gauge?
Are normal late Leyland Mini's badged as 'Leyland Mini' or still Clubmans? Cherry is a 76 Leyland Mini S and has both the S badge on the grill and the Mini Clubman badge on the boot?
Sorry Jess I meant to say Leyland Mini S I will go back and edit it. :cry:
PostPosted: Thu May 21, 2009 5:28 pm
They stopped using that when they started making rust-prone Minis at the Enfield plant. :lol:
Bubbacluby wrote:
floor pans are different...
reversing lights got added i think...
Steering wheels.
clocks origianlly in miles and km's then only km's.
side mirror used to be chrome then went to black plastic one.
carpet eventuall went to a moulded type early ones had many pieces. seatbelts had retractables at the end not at start......
The side Mirror was the same right though. :wink:
PostPosted: Thu May 21, 2009 7:03 pm
Thanx all, that shut him up, thanx for the ss flyer
PostPosted: Thu May 21, 2009 9:21 pm
Are you sure because i my GT had a chrome one (what was left) when i got it, and my 78mini S had a black plastic one... maybe that was an after market job........ must have been :? :? :? :?
PostPosted: Fri May 22, 2009 10:02 am
Rotodip > Rust
:lol: LMAO
2008 Prado GXL
PostPosted: Fri May 22, 2009 10:55 am
ginger ninja
ginger ninja
Cherry is 76 and has a chrome side mirror?
sports850 wrote:
PostPosted: Fri May 22, 2009 4:23 pm
They were all made with a chrome side mirror.
Users browsing this forum: Bing [Bot] and 72 guests
