And another (better) one-
STOCK-CODE: KC5300 RRP: $62.95
Qty 1+ $62.95 Qty 5+ $56.50
Digital Fuel Mixture Display Kit for Cars
Refer: Silicon Chip September and October 2000
This brilliant dashboard mounting unit monitors and displays your car¹s air-fuel ratio in real time on a three digit display and at the same time on the programmable 10-LED bargraph. Indicates ratios between 11.8 - 20.6 for petrol and 12.7 - 21.5 for propane/LPG. Some features: fully lean and fully rich indication, fast 220ms update time for bargraph, 440ms upgrade time for 3 digit display, 0-1V display for setting up adjustment, dot or bar option for bargraph and auto display dimming for night driving. All this in a compact case measuring only 83 x 54 x 31mm. Leaded petrol engines will soon poison an EGO sensor, so it is recommended that kit be used for tuning purposes only.
Kit includes case with PCB¹s, pre-programmed PIC micro, 7 segment displays, red acrilic, hook-up wire and all electronic components.
- Case includes a laser cut & silk screened front panel
- Clamp included
I'll buy one to play with..
