It is currently Mon Jul 21, 2025 12:41 am
PostPosted: Sat Mar 12, 2005 11:21 pm
I'll add you to the list.... :)
these things pop up so rarely, and even more rare, i dont want it !!
I'm gonna stick to small-block power i think.....
I DID have some evil thoughts this afternon whil epulling it apart...
I've got a new Blower on the way, need to do some head-work... hmmmm
Nahh, lets see what a small-block can do.. I'm told the "limit" is 140 .......
Pffft, i reckon it'll be more like 150....... :P
J
PostPosted: Sun Mar 13, 2005 5:31 am
Must have breathed real deep (not)- a 1275 sucking thru a single HS2.. :lol: :shock:
PostPosted: Sun Mar 13, 2005 8:29 am
150hp :o
PostPosted: Sun Mar 13, 2005 6:07 pm
did any one else notice that the oil filter is on upside down
PostPosted: Sun Mar 13, 2005 6:33 pm
yeah i thort that was a tad weird,sorta like a MGB,it will get the arse in the way for a spin in oil filter,or maby a remote filter kit and have the fitler else where.
this will be my turbo motor now,the 1100 motor will go in the bin
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Sun Mar 13, 2005 6:43 pm
Clubman, I'll put a spin on housing in there as well as a nice rocker cover....
most of the nasty looking bits have cleaned up nicely....
J
PostPosted: Sun Mar 13, 2005 8:03 pm
I reckon it was either a pump motor or a stationary power unit. Weight was certainly not an issue with a cast iron (or is it alloy)? sump. Either way it is an industrial motor. Leyland / JRA had a dedicated power products division which looked after this sort of thing It was at least late 60's as it has a pcv valve.
Chris
Everything I like is either
PostPosted: Sun Mar 13, 2005 9:26 pm
looks like someone has got a 1275 motor,done some mods and stuck it on a boat,that gearbox is alloy.
thanks for the spin in filter and the roccer cover kazjim :D
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Sun Mar 13, 2005 9:31 pm
a bit of spit and polish that look million bux! :oops:
PostPosted: Sun Mar 13, 2005 10:06 pm
she dont gotta look nice....
will looks better with a turbo next to it :D
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
Users browsing this forum: No registered users and 72 guests
