It is currently Mon Jul 21, 2025 1:43 pm
PostPosted: Wed Jul 08, 2009 9:00 pm
simon k wrote:
simon k wrote:
Just push the valve in with the pointy dome of the std steel valve cap.
if he had the flash valve chuck like some of us use, he could neatly squirt it into a container like I do 8)
I regard used hydro fluid like used brake fluid, only worse... :P
don't worry - I don't re-use it, but I do prefer not to have it spray up my arm and in my eyes ;)
What is wrong with 40 year old fluid in a 40 year old car? 8)
PostPosted: Wed Jul 08, 2009 9:02 pm
sgc wrote:
miniDave wrote:
The front still sits a lot lower than the rear
Sounds like the helper springs on the rear are a little bit tired...
:oops: Actually that reminds me that I haven't put them back on yet after painting!!!! (I am a dickhead)
Dave K.
PostPosted: Wed Jul 08, 2009 10:26 pm
This space for rent
:lol: :lol:
Glad to be of service :D
PostPosted: Wed Jul 08, 2009 11:04 pm
The original fluid is nice & sticky, has the consistency (and feel) of seagull's cum :lol:
Not like the stuff they sell you today - too watery. That's why I prefer to use Nulon coolant (the expensive stuff).
PostPosted: Thu Jul 09, 2009 9:54 am
Why not bleed the system from the front hydro unions. Thats what I do and usually get it in a single 'go' No air left.
PostPosted: Thu Jul 09, 2009 11:19 am
I did a pump up for a guy last month - I pumped it up with water and then squirted it out - the 40 year old stuff came out chocolate brown, and way thicker than seagull's cum
PostPosted: Thu Jul 09, 2009 3:11 pm
What clubs have you lot beeb going to, to know the consistency of a seagull's procreation paste.....
PostPosted: Thu Jul 09, 2009 5:37 pm
That is sort of what I do, but I have a Morris 1100 so you are filling it from under the bonnet anyway.
I fill the displacer with fluid before fitting it to the car.
I fit the displacer and leave the connection to the pipe loose.
I then push as much air as I can out of the pipe by lifting the wishbone which pushes fluid out of the bag.
Once it starts pushing fluid out of the connection I do it up tight.
Then I pump it up.
You can get all the air out of the system if you are careful.
I have been going to make a simple vacuum pump but I haven't got around to it yet.
I have been toying with a few ideas for getting the required vacuum.
The easiest way that I have come up with is to use inlet manifold vacuum. :lol:
PostPosted: Thu Jul 09, 2009 6:29 pm
Umm just thought I would put it out there if u have a pump with a vacume that don't hold pressure don't that mean u got a leak in your hydro line some were all I no is when my bro was doing his hydo he had a lot of problems with leaks ect cause it wouldn't hold pressure just thought I would have my say
PostPosted: Thu Jul 09, 2009 11:27 pm
Keh? :?
PostPosted: Fri Jul 10, 2009 2:18 am
i acquired a mini wrote:
I would just like to suggest that if you have a pump with a vacuum that doesn't hold pressure, doesn't that mean you have a leak in your hydro line somewhere? From experience, when my brother was doing his hydro, he had a lot of problems with leaks etc. because it wouldn't hold pressure. $0.02
or
i got a mini wrote:
If you have leaks in your hydro system, it won't hold pressure.
:roll:
tim
PostPosted: Fri Jul 10, 2009 9:30 am
PostPosted: Fri Jul 10, 2009 1:31 pm
A question for hydro pump up experts.
If you don't use the vacuum pump and rely on the pressure to force out trapped air by dumping the fluid fast how do you ensure that air bubbles trapped in aerated fluid are removed or isn't it a problem?
RonR
PostPosted: Fri Jul 10, 2009 2:05 pm
I would guess a small qty of air is no big deal. Not the same situation as if you have aerated brake fluid. I don't believe there would be a perfect vacuum using the vacuum pump anyway.
PostPosted: Fri Jul 10, 2009 2:59 pm
This space for rent
Air left in the system just contributes extra "spring" effect (softening the ride a little) and reducing the fore-aft flow of hydro fluid. No biggie if it's a small amount, especially if you have fitted comp. rear bumpstops and front shocks.
