It is currently Sun Jul 27, 2025 7:26 pm
PostPosted: Fri Jul 24, 2009 7:06 am
Leighton wrote:
if your talking about removing the drive flange from the hub you could use a hydralic press if you have access to one...
I have a homemade slide puller for this-
A long bit of bar with a plate welded on one end and a wheelnut on the other, the sliding weight is an old M1100 balancer.
Works for me... :wink:
PostPosted: Fri Jul 24, 2009 11:17 am
there you go... much cheaper than buying one.
i had access to one at school.
worked for me :wink:
 Post subject: The end.
PostPosted: Sun Jul 26, 2009 10:49 am
Thanks to all the suggestions. Finally got it off and everything is looking sweet once again :)
PostPosted: Sun Jul 26, 2009 11:39 am
This space for rent
I think it was an Ausmini'er who got a stuck hub (drive flange) off with a length of chain and a sledgehammer.. each end of the chain bolted to a wheel stud, then a couple of good belts on the chain with the sledgehammer.
PostPosted: Sun Jul 26, 2009 7:44 pm
Give Ash some flowers Nick .
That was me :) Worked great considering the inner race of the outer wheel bearing was rusted onto the flange. It saved me from undoing brake hoses and having to re-bleed the brakes etc
Users browsing this forum: stewartp and 92 guests
