Next Update:
During the week Dave fitted my brand new LCB/RC40 exhaust. He is such a perectionist, measuring, fitting and refitting just to make it perfect.
I fitted competeion rear bump stops, only to find out the bump stops that had fitted previously (not by me) were fitted the wrong way around so that they would never work.
Yesterday my mentor came over to help out again. He sorted out my shifter problem by stripping down the remote and reasssembling it. Now its great.
Now more problems, its two steps forward and one step back with Slidey.
1.
It developed a massive and consistant mid fire above idle. Dave checked fuel in the carb and then we swapped the electronic ignition. Still had the miss fire. Dave narrowed it down to a short. He disconnected a couple of wires and it ran sweet. I think that I need a auto electrician.
2. Horn doesn't work. No power to the horn. (Dave just popped in and fixed it)
4. With my new battery Dad had to make a new battery hold down as it was too high.
5. The clutch doesn't work!!!!
Dave correctly set up the clutch/flywheel assembly so I knew that that area was spot on. Hydrolic? maybe it had a master cylinder that was too small. There wasn't enough push of the arm. Looked like I needed a new master cylinder. Bloody Slidey!!!
This morning I took out the drivers seat to remove the cleavis pin. Picture this, a massive Elephant Seel/Walrus laying on his back on the drivers side floor of a mini. lol
Anyway I discovered that there was no pin! yep no cleavis pin holding the master cylinder to the pedal. Shouldn't be suprised as MANY things were left off the car or not fitted correctly. You guys remember the 'reconditioned' engine problems that the previous owner had with Slidey.
Time is running out. Some late nights. Wednesday I have an over night in Goodoowindi for work so that night is out.
Fingers crossed.......
