[quote="david rosenthal"]Where are you located?
If you are in SA then I can show you how to do the job. A few little tricks like making up jigs to get the front/rear windows exact size and shape. Where to cut the "B" pillar to miss all the reinforcing for the seat belt mounts . I also fit a insert into the pillars when re-joining.
I have chopped down a few cars and a straight out roof re-placement is very easy.[/quote]
David, just asking, but how much of the car do you remove when you do this job? I've only done it on the earlier spot welded cars. If you cut it just below the drip rail on the later cars, I thought you should be able to leave the pillars and windows in shape? As long as you don't take it for a drive down the freeway 80mph with the roof missing you shouldn't really need any jigs? There is a small bit of flex when the car is sitting stationary on the deck (if you push the sides or give it reason to flex) but not enough to cause any damage (unless you do something deliberate), when you put the new roof on it should bring it back square... Is there more rust in the car than what we know about or something?
The other way of going about it is to cut the roof right in the gutter and then grind of the remainder of where the old panel met the gutter, that way you don't need to cut below the drip rail at all, so you still have that rolled edge the whole way round giving it support. Plus if memory serves, inside the car where the hood lining bows fit is a pretty strong section to (stronger than the rolled edge for the drip rail) that goes the whole way round car. That with the drip rail should provide enough strength to romove the roof and replace it with out rigging provided you don't start moving the car around, its roof off roof on.
As I said I have not changed a later roof, so what I'm saying is only how I would go about it, not what i've done... Is there something about the later cars I don't know about? Obviously there is a reason you go to that much effort, sorry I just picking your brain a bit to find your way of thinking
