It is currently Tue Jul 29, 2025 1:59 pm
PostPosted: Wed Oct 28, 2009 6:14 pm
estapol wrote:
Ok im just running off the top of my head as an avionics tech, but you could most probably use any gauges in a mini its just a matter of remanufacturing the looms that come from various components to the back of the gauge..... wouldnt be too hard just a bit of persistence and crimping and you can have any gauge cluster you like.
Please someone tell me if I'm wrong
Cheers Hoba
Yeap, that'll work OK. May need to have the speedo re-calibrated that's about all.
PostPosted: Wed Oct 28, 2009 6:29 pm
Not that easy in most cases. For some reason most cars have different resistance readings on the gauges for fuel and temp and the gear / diff / wheel size ratios are never the same for the speedo. Tachos can be made to work easy enough.
Modern cars now though are moving away from all that stuff and going into making the gauges read directly from coded signals or pulses from the engine management computer. This makes it harder to use the gauges as they come out of the car, but with some clever modifications they could be modified to work.
A simple example for a custom setup would be to get some late rover gauges. The needles on these have internal rotation stops so that you can pull the needle off and change its zero position or even change the needle altogether without affecting the calibration. See example below:
So by using these internals, you could put them onto a single custom display board with numbers for tacho and speedo and put the fuel and temp gauges wherever you like, or replace them altogether with aftermarket ones.
I'm happy to take offers on the gauges shown in the pic. Ideal for a custom setup! :D
PostPosted: Wed Oct 28, 2009 7:51 pm
blake12345 wrote:
as I drive off the rpm
I did that for a year or so in my Mk2 Jag.....you do get quite use to it......
never got booked......but then again that was a lucky car.... it seemed impossible to get booked......even the night I was pulled over
doing 100k in 80k zone and it was unregistered (out by 1 week)
