There are various types of electronic ignition systems. Most new cars have the spark triggered from the crank, with separate coils to each plug. Sometimes the coil is ON the plug. But I digress..
As applied to Minis you have the good old Lucas coil ignition system with points and a condenser. Yes it works most of the time, but things wear and the spark deteriorates, and the timing gets retarded too.
Electronic ignition uses no points these days- instead they use an optical trigger or a `Hall-effect' sensor to get spark from the coil.
Electronic ignition for a Mini can be achieved by fitting another dizzy (eg Honda, Nissan) with its electronics and coil, or by buying a converted Lucas dizzy (eg Aldon red or yellow) or by buying a kit from Pertronix or Piranha etc and fitting it yourself.
Some benefits of electronic ignition (I've used a Pertronix for 3 years):
1. No points to adjust or wear out.
2. Ignition timing stays correct for long periods
3. Less ignition problems in wet wearher
4. Fatter spark due to more rapid switching compared to points
5. Can run bigger spark gaps- better economy, maybe power..
6. Less spark scatter (timing vatiation)
7. Smoother running
8. Higher rpm capability- no points bounce
