It is currently Wed Jul 23, 2025 1:34 am
Post new topic Reply to topic  [ 53 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Mon Mar 28, 2005 8:58 pm
my hats off to you for building a g'box yourself, i wish i had the balls to do it :lol: :wink:
PostPosted: Mon Mar 28, 2005 9:00 pm
Gearboxes are easy, once you work out how to take apart/put back together and what to look out for. :lol:
PostPosted: Mon Mar 28, 2005 9:17 pm
I will be getting a fair bit of help. and thanks doc i will go with the $90 one because i want it to last.
PostPosted: Tue Mar 29, 2005 7:15 am
get the rebild kit from minispares uk plus the comp diff pin and thats almoust everything you need (including gaskets and oil seals).
PostPosted: Tue Mar 29, 2005 7:29 am
PM sent. 8)
PostPosted: Tue Mar 29, 2005 8:45 am
The Gearbox kit from Minispares actually looks like a pretty good deal .. . .
Hmmm I wonder if its time to rebuild "ol whiney" yet .....
Kev, that kit with a comp pin should be all I need for a rod-change box ?
Would it include the actual rod-change shaft seal ?
Comparable prices to our mates at Karcraft ?
Hmmmmmm
J
PostPosted: Tue Mar 29, 2005 7:26 pm
Hmmmmmm
J
Yeah it's cheaper to bring the kit in. Get the S 1st motion shaft & laygear kit http://www.minispares.com/Product.aspx?pid=37122 while you're at it.. 8)
The overhaul kit includes the rodchange shaft seal.
PostPosted: Tue Mar 29, 2005 7:32 pm
how much is a rebuild kit from supplyer in aus
PostPosted: Tue Mar 29, 2005 7:50 pm
No such thing here really. Need to buy the bits separate. :cry:
PM Mike- he priced the exercise, then brought the kit in. :wink:
Karcraft do a bearing kit (4 synchro boxes) for $140 but that excludes the idler and diff bearings, and everything else you will need.
PostPosted: Tue Mar 29, 2005 7:59 pm
Gee it only doubles the price....
Dunno if i can justify - the extra for the little gear ratio change.....
is it really THAT much of a difference ?
we're talking budget here.. 'ol whiney is making me nervous thats all .....
J
PostPosted: Tue Mar 29, 2005 8:34 pm
J
Less gap 3rd to 4th is all, gap between other gears is the same. Raises 1-2-3 by 1/17.
Probably hardly worth $$$ really, although Mike did it. :wink:
PostPosted: Wed Mar 30, 2005 8:04 am
Gee, thanks Kev, thanks for the reassurance. :)
James the difference in terms of your driving experience is not quite negligeable but is not drastic by any means (or maybe Kev just kept the 22g1040 cluster and told me its in ;)). But I did get the conversion kit for free (long story) so it was either to go into my ever growing "to be sold one day" pile or into the car - and that pile is begining to stink and attract small rodents quite frankly, also children get lost inside.
My reply to Stuartminidlx had all the prices in it - dont have a copy as my PM outbox was full - but maybe he can post it.
PostPosted: Thu Mar 31, 2005 6:23 pm
Mike, Stuartminidlx didn't take the bait and post the prices. do you think you could oblige with some details?
Kevin.
PostPosted: Fri Apr 01, 2005 7:14 pm
1) MSG20 - GEARBOX 4 SYNC REBUILD KIT LESS DIFF PRE A PLUS 14MM MAINS 1 £85.17
2)C-AHT54 - PIPE,HITECH CENTRAL OIL PICKUP PIPE 1 £22.50
3)C-AJJ4032 - GEAR KIT 22G1371/22G1040 ONLY TO CONVERT TO "S"RATIO 1 £82.55
4) C-BTA166 - DIFFERENTIAL PIN UPGRADE (SEE C-BTA167 ALSO) 1 £13.00
there they are sorry i have been abit busy
stuart
PostPosted: Sat Apr 02, 2005 9:57 am
i am thinkin of getting a straight cut crownwheel and pinion as they are only 10 pound more. would this improve the strenght of the crown wheel and pinion. Here is the list so far though
PIPE,HITECH CENTRAL OIL PICKUP PIPE £22.50
GEARBOX,4SYNC REBUILD KIT INC DIFF PRE A PLUS 14MM MAINSHAFT £119.66
3.4 CROWN WHEEL & PINION PRE A PLUS 22A411/413 £105.00 Or this CROWNWHEEL 4.1 62 TEETH PRE A PLUS TYPE Price £46.00 Part No. 22G101 but i don't what the matching pinion should be.
or this for the cheap option
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&category=32072&item=4539047008&rd=1&ssPageName=WDVW
