It is currently Mon Aug 11, 2025 2:07 am
should i fit spot lights to my clubman
No,Never you fool. 15%  15%  [ 7 ]
Yes ,but very unnoticable.(behind grill ect..) 4%  4%  [ 2 ]
yea, only 2 26%  26%  [ 12 ]
go for it, 4 big ones up front. 51%  51%  [ 24 ]
2 on one of those horrid nudge bars. 4%  4%  [ 2 ]
Total votes : 47
PostPosted: Wed Mar 31, 2010 10:20 am
NAV how about this
:lol:
PostPosted: Thu Apr 01, 2010 11:56 pm
sgc wrote:
deluxe_68 wrote:
Harley wrote:
it's illegal to drive with them turned on unless you're in the country.
That is incorrect, the rule is they can be used were there is no street lighting.
Actually (in Victoria at least) that's incorrect too -- they can be used anywhere if you need more visibility and there are no cars ahead of you for 400m.
Well, actually.....
Australia has had uniform traffic laws for a number of years now (since 1999 if I remember correctly) with local additons for things like hook turns in Victoria etc.
The distance is 200m or if the use of the lights is dazzling another driver eg if you can see the lights are shining on the other car. There is no mention of rural or built up areas, only the proximity reference.
Driving lights should be wired in to work only with high beam. They are of a higher intensity than low beam lights so even when directed at the road they can be distracting to other drivers.
Fog lights (the yellow ones) can be wired to switch on independantly of other lights but can only be operated in fog.
Might be worth a read if you aren't up to date. Go to your state government webpage and do a search on legislation, then Road Rules. You want the "use" act not the "management" one..
Alec
PostPosted: Fri Apr 02, 2010 6:56 am
Driving lights. Must not be fitted higher than original headlights of vehicle. They must work only with High beam and must be also controlled by a separate switch which will allow Hi beam to come on without Driving lights. Single or odd number of driving lamps not legal. Driving lamps mounted higher than headlight level must be covered and must only be uncovered and used when off road. ADR.
"Let us remove your "SHORTS"
Last edited by Convertible Mini on Fri Apr 02, 2010 7:28 pm, edited 1 time in total.
PostPosted: Fri Apr 02, 2010 1:48 pm
Thanks Tony. Forgot to check the ADR's. I wasn't aware of the height rule. I have two, they are lower and have their own switch so I gather thats legal..
Alec
Users browsing this forum: No registered users and 179 guests
