Hey great topic,,
one I've been pondering a couple of days actually.
I've heard the same sides of the argument you guys have all raised
"bad for longevity cos it holds the moisture in and makes them rust"
"not a drama, done it it works fine but with no real Hp advantage worth mentioning"
So, I was thinking about trying it out myself.
I actually electro-plate my extractors,
.. its great for rust proofing and its inside and out plus its dirt cheap
. So I don't think that I'll have the same problems with rust... (at least not for the first 20 years
But my question is ---> how much heat does it keep out of the engine bay?
Reason I got thinking about it was cos the other night my car was in a situation where it ended up idling for about 35min with no air moving around the exhaust and more importantly,,,, none around the float bowls
It got so hot in there that even the dash post on the SU's were to hot too touch
,, normally they're pretty cool..
So it ended up missing really badly for a bit there untill it had a chance to cool down properly (about 10 minutes)....
Morris has said that it helped with this problem on the HQ's... but how effective was it?
Any numbers on what kind of reduction in engine bay heat you can expect?
EDIT--> spelling
