It is currently Tue Aug 12, 2025 4:43 am
PostPosted: Mon Jan 04, 2010 9:52 pm
If still loose with the proper spacer, read my Timken bearing thread in the how-to forum.
PostPosted: Mon Jan 04, 2010 10:25 pm
Also just make sure your not using a drive flange thats worn out.
Did the old bearings look to be the cause of your problem?
PostPosted: Mon Jan 04, 2010 10:59 pm
There was a bit of wear on them, but the bearing faces were still pretty smooth and clean.
The grease inside them was almost tar it was that thick. So they were on the way out. Ill finish the job off and swap the spacers over and see how i go.
Thanks for your advice everyone.
Simplify and add lightness
PostPosted: Mon Jan 04, 2010 11:02 pm
And Doc, I read your article the how to section a while ago, and really should have reread it again before i did it.
from what i read the problem is the long spacer that i put in is causing the slop.
Oh well, live and learn, i wont be making that mistake again.
PostPosted: Tue Jan 05, 2010 7:27 am
blue_deluxe wrote:
when i bolted it all back together theres a lot of play in the drivetrain (maybe 10 degrees from diff output through rubber unis into cv then onto drive flange). Is this normal? Joe
Sounds like the rubber universals could be the culprit. Not known for their longevity if subject to hard driving or they have not been installed properly (u-bolts overtightened).
PostPosted: Tue Jan 05, 2010 6:45 pm
blue_deluxe wrote:
when i bolted it all back together theres a lot of play in the drivetrain (maybe 10 degrees from diff output through rubber unis into cv then onto drive flange). Is this normal? I dont remember it being that sloppy before.
Classic symptoms of a worn diff pin and planet gears.
I'd change them before they go BANG and the broken pin spears a hole in the casing. Then all the oilz runs out. :cry:
PostPosted: Wed Jan 06, 2010 3:52 pm
Hi doc,
I think it is the diff pin thats gone. I swapped the spacer with the proper one and reassembled it all back together and the noise is still there.
Its also the same whether the wheels are straight or turning.
Whats worse is i sold my spare engine 2 days ago. The only reason i kept it round for 6 months is as a spare engine. Karmas a bitch.
PostPosted: Wed Jan 06, 2010 6:00 pm
blue_deluxe wrote:
Hi doc,
If the noise is there whether going straight or on corners then it wouldn't be the diff pin. If it sounds like it's coming from that general area, then I'd guess at the Main shaft Bearing in the Gearbox.
PostPosted: Wed Jan 06, 2010 11:04 pm
Thanks for the advice. Its off the road now, so ill have to get the engine out and split it apart to have a look.
Users browsing this forum: No registered users and 183 guests
