It is currently Mon Jul 21, 2025 7:53 am
PostPosted: Sat Dec 19, 2009 9:34 pm
Oh dear, worry, worry...
Hi
I ment to say if you want one of these manifolds you can get them from Keith but they are a special order and a little expencive
Graham Russell
PostPosted: Sat Dec 19, 2009 9:57 pm
G'day Graham what do you consider a "big cam" that the maniflow manifold doesnt work well with :?:
PostPosted: Sat Dec 19, 2009 10:01 pm
Hi Ballistic
Any thing up around the 300 duration mark but you could make a bigger balance pipe for it.
Graham Russell
PostPosted: Sat Dec 19, 2009 10:02 pm
I think he maybe talking about something like a Kent 310 scatter
And I still want to see someone put triple 1 1/8 SU's with custom manifold on an 850 :)
PostPosted: Sat Dec 19, 2009 10:08 pm
Hi 74Snail
Triple 1.1/8 ?????????????/
PostPosted: Sat Dec 19, 2009 10:17 pm
GR wrote:
Hi 74Snail
Oh come on Graham, someone has to do it on an 850, it would be a bugger to balance, oh , hang on , it would fit , but would it work ?
PostPosted: Sun Dec 20, 2009 8:37 am
Actually it would be better with quad 1 1/8 SU's I,ll start a separate thread so I don't hijack this one anymore :)
PostPosted: Sun Dec 20, 2009 10:11 am
HI ALL
One thing we have noticed with the standard manifold running 2x 1.1/2 su's with a cam around 276 duration and smaller at around 7000rpm one slide will suddenly drop to about half way open,now lifting the slide while the engine is running makes no difference to the power, now david visard rang me about the same problem as he had motors doing the same thing and the one thing that was common was that 98%of of the motors that did it had a modified manifold on it, in saying this i have seen this with a std manifold, the only conclusion i can come up with is that the motor thinks it has bigger carbs than it has, in other words the motor is over carbureted for the cam it is running, because the motor does rob from one carb the other carb and may be the modfied manifold is becoming to efficient for the motor with the big balance pipe, hence for the washer with a smaller hole in it.
Graham Russell
