It is currently Mon Jul 21, 2025 4:58 am
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
PostPosted: Sun Dec 20, 2009 12:20 pm
deluxe_68 wrote:
GT mowog wrote:
kemal wrote:
ripped out all plugs they were black as poo poo not wet , i cleaned em up put em all back in started for a bit then went back poo poo ,pulled one back out and it was black as poo poo again?
Sound like it's running quite rich. Is your choke stuck on? I doubt that it were your condensor, as it wouldn't start at all and your plugs would be wet, not black.
What type of carbie(s) have you got?
I have had condenser's fail before and they would still idle but run like crap under load. Does sound like it is rich though.
Cheers Pete
Yes Pete, that can happen, but the plugs won't be black. It appears to be a fuel problem rather than ignition. Cheers
PostPosted: Sun Dec 20, 2009 12:21 pm
NAV-MAN
1310/71 wrote:
Do you have the pulsar dizzy still?
If so, I don't think you have a condensor. You need to check for spark at the lead. Maybe the ignitor module in the dizzy might have failed.
It would also pay to check all the connections on the coil, dizzy etc for any loose or disconnected wires.
KB
A blown module would make no spark and the plugs would be wet
Have you checked your fuel system? is it all working well and the filter clean? Is the fuel bowl full of fuel?
PostPosted: Sun Dec 20, 2009 1:14 pm
twin 1 and 1/4 su's , fuel is going through fine ,filters new bout to put new plugs in and try and start it if nothing ill check dizzy
PostPosted: Sun Dec 20, 2009 1:21 pm
Check on both carbies that the choke is OFF. Underneath each carbie, roughly in the middle, you'll see a round tube hanging straight down with a linkage on it to your choke linkage and cable. Make sute that these are pushed up as high as they will go (choke off).
Also, has any fuel been coming out of the fuel bowl vents? Could be a jamed 'needle & seat' in one of the fuel bowls.
PostPosted: Sun Dec 20, 2009 1:38 pm
changed plugs and check dizzy , runs but runs like a absolute dog , with black smoke out the exhaust
PostPosted: Sun Dec 20, 2009 1:58 pm
looks like was a choke problem running now
PostPosted: Sun Dec 20, 2009 6:08 pm
NAV-MAN
The simplest of things often give the biggest headaches
PostPosted: Mon Dec 21, 2009 3:11 am
kemal meant to write:
Many thanks to those who took the time to help me out, especially to GT mowog who got it right first go then patiently directly me three times to the choke, where the problem was.
PostPosted: Mon Dec 21, 2009 3:50 pm
Hey Graeme H, no worries, it can difficult to do these type of diagnostics by brail.....
Have a Merry Christams......
PostPosted: Mon Dec 21, 2009 4:40 pm
I think Graeme's post is meant to be a gentle prompt to kemal that a polite 'thank you for your help in fixing my problem' wouldn't go astray.
PostPosted: Tue Dec 22, 2009 7:58 pm
Sorry guys i have been flat out last 2 days at work i am currently resigning so has been really hard trying franticly to find work and other stuffs going on in my life right now.thats why it was so urgent to fix it ,
THANK YOU so much guys , its so great that you guys help out everyone and is much appreciated you saved me alot of money because i would have taken it to a rip off mechanic otherwise, cheers and hope you have a merry xmas.
