It is currently Fri Aug 15, 2025 12:31 pm
PostPosted: Mon Jan 11, 2010 8:48 pm
Harley wrote:
I wouldn't try and short the starter motor.
Why not? All you are doing is applying power in the same manner that the solenoid does. (connecting one post to the other)
PostPosted: Mon Jan 11, 2010 9:01 pm
On a 60's car sure, but it's a bit harder on the rover starters and given the guy has caused the whole problem by removing the dipstick I wouldn't want to see anything go up in flames as a result of 'short it with a spanner'.
Why not remove the starter from the car and connect to a battery? If it's stuffed it's already out, if it's fine there's no risk of damage to the cars electrical system.
PostPosted: Mon Jan 11, 2010 9:05 pm
:oops: we tried that as well.............. pulled the battery out, connected earth to the engine and to - on the battery and then connected + of the battery and then tapped the end of the solenoid. Got nothing........... :cry:
tried it on the moke and she went che chu.... like she sneezed. Kinda cute. But it tested our theory.... if the solenoid on the Rover was OK, there would have been something.
She is being flat bedded out to Greig when i can afford it....
For now I will install the new carpet, seats, roll cage, parcel shelf, speakers, door cards and fix the rust in the door......... :lol:
PostPosted: Mon Jan 11, 2010 9:19 pm
Call me crazy but the symptoms you describe sound like the joiner block on the ignition are stuffed, where the loom from the ignition switch(key) joins at the bottom of the column can and does loose good connection, first signs are that the blinkers and radios and things that are ignition controlled stop working, also stops the car from running.
It does not effect the things like headlamps and horn and hazards as they are not powered by this switch, they are powered at all times direct
pul the block apart and give it a sqirt of wd40 and make sure that it has good connection, it also controls the starter
Hope that helps
PostPosted: Mon Jan 11, 2010 9:20 pm
Pull the starter out of the moke then! :lol:
PostPosted: Tue Jan 12, 2010 6:57 am
Do you hear the fuel pump kick in when you turn the car onto accessories ?
PostPosted: Tue Jan 12, 2010 7:07 am
Fuel pump should not kick in until the key is ON not accessories.
Cheers Pete
PostPosted: Tue Jan 12, 2010 7:51 am
Cheers Pete
yeah I dont get anything from the fuel pump. And yes.... it did only ever power up once you clicked the key over to the on position...
PostPosted: Tue Jan 12, 2010 7:55 am
The fuel pump still works now though? There's a reset button and a fuse for it somewhere, but even if the pump has an issue the car should still crank, just wouldn't start.
PostPosted: Tue Jan 12, 2010 8:19 am
no no... i dont get anything from the fuel pump either....
PostPosted: Tue Jan 12, 2010 9:18 am
Have a read through the following forum, it is specific to the SPI and MPI.
Lots and lots of info, but very helpful.
SPI and MPI specific
Cheers Pete
PostPosted: Tue Jan 12, 2010 10:38 am
Cheers Pete
Thanks Pete... heaps of info there, but every time someone posts a "My car wont start" problem there are no answers... hahahahaha :lol:
ploughing through it all now though. I will hopefully get there with something.
Users browsing this forum: No registered users and 281 guests
