Hi there guys.
You wont be needing cable the size of 70 or 90mm2 for this. Thats more than adequate but far too big. 70mm2 has a continuous rating of 220 amps continuous (75deg insulation) and 270 amps continuous (90 deg insulation) where as 95mm2 is rated at 270A (70 deg) and 330A (90 deg).
I haven't bothered to work out what the short circuit capacity for these cables are, but it will be huge!!!
I can buy 70mm2 flexible cable for about $20 per metre - TRADE - so i'm not sure what the electrical wholesalers would charge you retail! probably at least half again if you walk off the street (someone can correct me if i'm wrong).
25mm2 costs about $10 per metre less and is more than adequate to do the job, remember its not the continuous rating your after as for this cable it is only 115A (70 deg) and 140(90 deg). This cable will be able to do a massive short circuit current for the time you are cranking.
The fitters at work have 70mm2 jumper cables, but the have to jump start up to 300kW underground machines that run 2 900CCA truck batteries.
I have 38mm2 cables at home, its a weird size because its Japanese (from a factory I once worked at) and this is way bigger than I would ever need.
Pinched for another website
"Many people gauge the strength of jumper leads by the thickness of the cables. The danger here is sometimes the insulation makes up the bulk of the cable, leaving a very thin amount of cable core to carry the current from the donor to the flat battery. Have a closer look at where the cable core is secured to the jumper lead clamps. Firstly look for a good connection, and there should be a reasonable amount of core cable in relation to the total cable thickness. Poorly crimped connections can fail if the jumper leads are in regular use, as the angle of the cables when connected can cause the inner core to work loose. Diesel engines operate on a much higher internal compression ratios, so more electrical load is placed on the cables in comparison to an average-size petrol engine. The thinner-cored jumper leads can suffer from sever overheating, and in most cases the amount of current flow is insufficient to boost the flat battery."
You will probably find that these cheaper jumper leads are only 4mm2 maybe 6mm2 for higher current ones.
You will find that 16mm2 cables would jump start a car more than adequately.
No problems with crimping cables at all with the correct tool as Mick said. Soldering is also good if you can solder properly.
With clamps, either do what the Doctor has said or get decent battery clamps. These have a strap that goes from one half of the clamp to the other half. This means that you have the whole clamp making a connection and are not relying on a rivet and spring for the other half of the clamps connection.
Any way thats my 2 cents if your interested
