It is currently Sat Aug 09, 2025 1:21 am
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
PostPosted: Mon Mar 22, 2010 7:53 pm
blue_deluxe wrote:
. Not just use this, this then that and wipe with that.
Hmmm need advice on what to do in the toilet hey??? :-)
PostPosted: Mon Mar 22, 2010 8:05 pm
Yeah, someone recommended 24 grit sandpaper then wipe clean with vinegar.
Simplify and add lightness
PostPosted: Mon Mar 22, 2010 8:08 pm
You could also try detol on a wire brush. Works great for me.
PostPosted: Mon Mar 22, 2010 8:19 pm
This space for rent
Phat Kat wrote:
But don't get used to it.
Bah.
PostPosted: Mon Mar 22, 2010 8:25 pm
I just remembered......Back when I bought a brand new Triumph Trident
it came with......believe or not....chromed disc brakes.
So after a near miss in Beaudesert in the wet, I took them some where that I
don't remember and I think they used an acid bath to remove the chrome.
Sorry just can't remember the details.
PostPosted: Tue Mar 23, 2010 7:42 am
The stripping process needs to be done in 2 stages depending on the substrate
Assuming its steel then the crome is removed in a sodium hydroxide bath with reverse current of about 6Volt pressure
To remove the next coat which will be nickel - this is done a sulphuric acid bath with reverse current of about the same for crome The anodes used are lead. This process will also remove the copper
Different process if the base is brass
Some plating is done el cheapo by eliminating the copper stage
I would give it to you plater but make sure there is NO grease or oil ANYWHERE including the gauze in the breather It contaminates his bath and the price will go through the roof!!!!
Mk1 Cooper S
Mini K Rally car
PostPosted: Tue Mar 23, 2010 3:04 pm
mini maxx wrote:
Just get another rocker cover, got a few here if you want to relieve me of one
PostPosted: Tue Mar 23, 2010 3:11 pm
bill.b wrote:
Original Q was re painting a chrome rocker cover. It's easier to strip & paint a painted one instead. :wink:
PostPosted: Tue Mar 23, 2010 6:59 pm
yeh if i can locate another rocker cover like the one i have i would be happy to prep and paint that instead of going to whole remove the chrome option.
my rocker cover has a breather comming off the top to the drivers side. i have a catch can all setup for this side.
does anyone have a rocker cover in ok condition i could buy?
needs to be the same as this if i can find it........
PostPosted: Tue Mar 23, 2010 10:49 pm
I have a boxful of covers in the back shed. But it will only be on the weekend I can check.
PostPosted: Tue Mar 23, 2010 10:50 pm
I might have one in the shed. Have to look though.
