It is currently Mon Jul 28, 2025 12:46 am
PostPosted: Thu Apr 07, 2005 6:41 pm
I mean your head looks like its been against a linisher - you know what a linisher is dont you?
Did you get the radiator business sorted yet?
PostPosted: Thu Apr 07, 2005 6:43 pm
No idea about the Linisher sorry.. :oops:
Nar going to look at the rad on the weekend..I'll put one of my other one's in for the time being
PostPosted: Thu Apr 07, 2005 7:31 pm
skssgn wrote:
does anyone else tap and block off the bypass altogether? the last couple of motors I did we blocked it off, which makes life much easier. Put a plug in the head, and tap & plug the outlet on the water pump.... no more leaking bypass hoses, no more lining the bastards up when you put the head on etc. etc.
the bypass hose is there to let a little bit of hot water stay inside the engine - it bypasses the radiator.... basically keeping the motor hotter, the poms needed it, we don't ;)
anyone else do the same?
Main reason for the bypass hose is to let water circulate thru the head and block during warmup, before thermostat is open. If you just block it off, the water pump will cavitate and there will be no circulation at all (unless heater circuit is open).
If you must block it , drill a few 1/8" holes around the thermostat. Race cars use a thermostat blanking sleeve which is pretty much the same as a partly open thermostat- but probably not great for a road car. :wink:
