poeee wrote:
Not rear. You don't need to upgrade the rear brakes at all. Again, make sure everything is in good condition. Make sure your rear cylinders match the front brakes (discs up front should have different cylinders at the back).
The only thing you could do is get some minifin brake drums.
poeee's right, the most efficient braking you can possibly have is the kind where there is absolutely no weight on the rear (endo) and the rear of the car actually lifts off the ground. so put simply its much easier to lock the rear wheels.
this is why when you fit disks 850 cylinders are put on the rear to send more brake bias to the front.
this is especially true on a front wheel drive car as there is no power going to the rear wheels at all.
think about what happens when you pull the front brake on a motor bike.
technically i supposed you could mod a front brake plate? not sure on this ?
