It is currently Sun Aug 03, 2025 8:14 am
Post new topic Reply to topic  [ 36 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Wed May 05, 2010 3:07 pm
Here's a crap photo, it's a Toyota 4afe manifold. You can see the injector being held between the fuel rail and manifold. It's not clamped down hard, you can still twist it, just sort of retained by the rail
PostPosted: Wed May 05, 2010 3:17 pm
Does a forced induction setup change anything when securing injectors?
PostPosted: Wed May 05, 2010 3:31 pm
Not really, most factory turbo cars use a similar set up to the photo posted. Some Subarus and Nissans use side feed injectors, but even they (in particular Nissan SR20's) have aftermarket fuel rail kits available, so they can use commonly available (and cheaper) standard style Denso/Bosch/Delphi high flow injectors.
Andrew
PostPosted: Wed May 05, 2010 5:14 pm
It was a bit of shock to me to, they're just a push in fit.
Simplify and add lightness
PostPosted: Fri May 07, 2010 9:11 am
Adding on to that, does a forced induction setup benefit from a EFI conversion over a carby?
1965 Morris Mini Deluxe - 998cc SC12
PostPosted: Fri May 07, 2010 9:21 am
In the setup I'm keen to try thr benifit is tuning. Done with a computer rather than playing with needles and springs.
PostPosted: Fri May 07, 2010 10:45 am
Might look into that costs related to a conversion then, since forced induction needs custom needles in a carby setup.
PostPosted: Fri May 07, 2010 11:17 am
Not really a bit deal, they have O-ring top and bottom of injector and are held down into the manifold by the fuel rail. No big deal.
PostPosted: Fri May 07, 2010 11:37 am
When I get my muscle car, Im so keen to run this:
http://www.retrotekspeed.com/products/p ... ystem.html
PostPosted: Fri May 07, 2010 2:12 pm
Throttle body injection that look like carbs. Works for me.
Check out the stromberg 97 lookalike's!
No SU's though.
PostPosted: Fri May 07, 2010 2:46 pm
jeez - that's what I was saying at the start of this thread - SU's are already just about ideal for an injection throttle body, just need the injector mounted :roll:
PostPosted: Fri May 07, 2010 3:25 pm
simon,
i'm looking at boring the jet out and fitting the injector in there. then all i have to do is fill the carb where the piston is. and hey-presto i have an SU looking injection set-up.
PostPosted: Fri May 07, 2010 3:40 pm
greyghost wrote:
simon,
beauty - keep me informed ;)
something like this under the dashpot?
PostPosted: Fri May 07, 2010 4:20 pm
Just need to get a throttle position sensor mounted and ya set. Probably bore the carb out so it's round where the normal jet sits, too.
PostPosted: Fri May 07, 2010 4:58 pm
was thinking the same thoughts
this way the fuel rail is below the "carb" and out of sight
i'm going to use a set of twin carbs, i was thinking of hiding the fuel regulator in the bottom of a fuel bowl. this way the fuel enters one carb, goes to the injectors via the fuel rail and then to the regulator and out the remaining carb.
