It is currently Sat Jul 19, 2025 9:50 am
PostPosted: Fri May 21, 2010 8:59 pm
yup. How much for a pulsar dizzy? Who does the conversions? Whats involved in fitting them? Is it something that is easy for me to do myself?
This is kind of a last straw. I getting sick of points.
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Fri May 21, 2010 9:04 pm
Read my long sticky thread at top of mods forum.
http://www.ausmini.com/forums/viewtopic.php?t=1498
Not hard to make fit (20 mins) but the advance curve needs mods (see GR).
They used to be $50 at wreckers including coil, are getting scarcer now.
Put a post in wanted forum if you can't find one.
Cheap alternative- add an electronic kit to your existing dizzy.
Going into my 1412-
came from here- http://www.brit-car.co.uk/product.php?x ... &xSec=5497
Also see http://www.simonbbc.com/automotiveshop/ ... cf8bf039b7 for example, there are others.
kits available here from `convertible mini', or Minisport SA.
Last edited by drmini in aust on Fri May 21, 2010 10:11 pm, edited 1 time in total.
PostPosted: Fri May 21, 2010 9:19 pm
Saves me buying a laptop to make a Megajolt work.
I reckon the default map that came with the megajolt was far superior to the pulsar anyway, so no need for a laptop if you don't want one :P
When I first put it on, it took me a few weeks to realise that the changes I was making to the ignition map weren't saving, there's a little button in the software to save the settings to the flash memory so they come back after power-off :oops: :roll:
I had to re-align my trigger wheel and the sensor on Tuesday night, so I made up an ignition map with 10* advance across the whole range, and shot my timing light at the flywheel - a little twiddle of the advance offset and the advance is spot on - such a good system
