It is currently Tue Aug 05, 2025 8:14 am
PostPosted: Sun Jun 06, 2010 6:28 pm
yep found it 22G1128
1971 mk2 police cooper s
1988 rover mayfair modified!!
PostPosted: Sun Jun 06, 2010 6:30 pm
wolfmini wrote:
it should be a mk2 cooper s box
OK, it will be either a 22G1128 or a 22G846. To be sure does it have Synchro on 1st?
This will fit straight on to your A+ 1275. If you have a 1275 engine (eg Cooper S Engine) on it now, use the primary gear from that engine, not the A+ one. The teeth are different.
PostPosted: Sun Jun 06, 2010 6:39 pm
yes it does have synchro on 1st.
i think i'll just do a straight swap, instead of gutting the recon rod change to put in the remote. (seems like too much hassle)
can the cooper s diff handle 100bhp or would you recommend upgrading it, i have a cross pin diff sitting on the rod change box ??
PostPosted: Sun Jun 06, 2010 6:44 pm
Depends on what you have in mind for it's use. Eg, street car, racer, motorcross, kana etc....
The standard diff in good order with a good quality diff pin and sun gears will take 100 HP OK but avoid spinning too often and with too many revs on.
If you envisage spinning a lot, use a 4 pin or quaiff diff.
PostPosted: Sun Jun 06, 2010 6:47 pm
so the cross pin diff in the rod change housing can be put in the remote housing?
is this something i would need to pay someone to do?
or could a backyard mechanic do it? (aka me, limited ability, but can normally work most things out)
PostPosted: Sun Jun 06, 2010 6:55 pm
Yes, the cross pin diff should go in the remote box OK. You should be able to swap them over yourself. I would recommend at this point that you get your hands on a workshop manual. It's not that difficult, but the manual does have fairly good step by step instructions.
Does both gearboxes have the same diff ratio? If so, just check that the gears have the same tooth design as there is early and very late types, not interchangable.
If the ratios are different or early / late crown wheel and pinion types, you will have to change the crown wheel. Again not difficult.
PostPosted: Sun Jun 06, 2010 6:59 pm
im pretty sure the same diff ratios
i know the new one is 3.44 and im pretty sure mk2 cooper s were also 3.44
i've got the black comprehensive workshop manual, gregory's and haynes
so i'll be taking it slow reading all 3 as i go
thanks for all your help gt mowog
PostPosted: Sun Jun 06, 2010 7:03 pm
Yes, standard Cooper S Diff is 3.44, just be sure to check they are the same tooth patern / type.
Your welcome, have fun doing your project :wink:
Users browsing this forum: Pottsy and 98 guests
