superSeven wrote:
Hanra wrote:
Clutch overthrow. Back the adjustment of the clutch off.
That's what I was getting at.
NG wrote:
Start car from cold idles fine Pretty much it warms up. drive take
Foot of pedal. Clutch in, revs drop down low, nearly stals or just stals.
Does it idle ok when in neutral, without the cluctch in? If you then disengage the clutch, do the rev's drop? If so your clutch is overthrowing, which correct me if I'm wrong, is putting a lot of pressure on your crank? (Hence the stalling)
Does it idle ok when in neutral,without the cluctch in
YES
NO
Thanks for the advice, i can not do much now as it's 1am. i just drove back home now.
the problems seems to come & go!
will update more tomorrow.
