It is currently Wed Jul 23, 2025 11:15 pm
 Post subject: Re: Wiring Problem
PostPosted: Tue Jun 29, 2010 4:11 pm
Convertible Mini wrote:
OR YOU CAN BRING IT TO ME AND I WILL DO IT FOR YOU !!!! IT IS WHAT I DO FOR A LIVING. "MINI AUTO ELECTRICS". See my Ad on MOCQ website and MAG. Good luck. And make sure you find a Sparky that does not mind working on Minis. Some don't like or know them. Be ware!! $1000. for a REWIRE is "very cheap" question the quality of the job you will be getting before yo have it done..
And you do great hi torque starters too. :)
PostPosted: Wed Jun 30, 2010 5:32 pm
mickmini wrote:
Sorry to leave that mess with you Dane, but the PO did make a real meal of it. At least I sorted out the battery cable when it was leaning on the exhaust.
vintage looms are the best by reputation. Make sure you tell them (or get the sparky to) what the extra accessories and guages are so that wires can be included for them.
michael
Haha Hi Mick! It is a bit of a mess isn't it. Where are you living now? still abroad?
Convertible mini I think you are a bit far :)
Dane
finally own one :D
 Post subject: Good a place as any...
PostPosted: Thu Jul 01, 2010 8:32 pm
Wiring Colour Code Table
Many British designed vehicles use colour coded cables to assist in identifying the various circuits in use. This is an extract from BS-AU7a 1983 Colour Code for Vehicle Wiring, from the British Standards Institution, 2 Park St., London W1A 2BS.
(Note that these colour codes may not apply directly to older cars. For example, the wipers on cars up to 1980 (at least) are not on a separate fuse circuit, so they are not orange, but green. Check the schematic for your car to be certain)
MAIN TRACER PURPOSE
Black All earth connections
BlackBrownTachometer generator to tachometer
BlackBlueTachometer generator to tachometer
BlackRedElectric or electronic speedometer to sensor
BlackPurpleTempreature switch to warning light
BlackGreenRelay to radiator fan motor
BlackLight greenVacuum brake switch or brake differential pressure valve to warning light and/or buzzer
BlackWhiteBrake fluid level warning light to switch and handbrake swith, or radio to speakers
BlackyellowElectric speedometer
BlackOrangeRadiator fan motor to thermal switch
MAIN TRACER PURPOSE
Blue Lighting switch (head) to dip switch
BlueBrownHeadlamp relay to headlamp fuse
BlueRedDip switch to headlamp dip beam fuse
Fuse to right-hand dip headlamp
BlueLight greenHeadlamp wiper motor to headlamp wash pump motor
BlueWhitea) Dip switch to headlamp main beam fuse
b)Headlamp flasher to main beam fuse
c)Dip switch main beam warning light
d)Dip switch to long-range driving light switch
BlueYellowLong-range driving light switch to lamp
BlueBlackFuse to right-hand main headlamp
BluePinkFuse to left-hand dip headlamp
BlueSlateHeadlamp main beam fuse to left-hand headlamp or inboard headlamps when independently fused
BlueOrangeFushe to right-hand dip headlamp
MAIN TRACER PURPOSE
Brown Main battery lead
BrowBlueControl box (compensated voltage control only) to ignition switch and lighting switch (feed)
BrownRedCompression ignition starting aid to switch
Main battery feed to double pole ignition switch
BrownPurpleAlternator regulator feed
BrownGreenDynamo 'F' to controlboxl 'F'
Alternator field 'F' to control box 'F'
BrownWhiteAmmeter to control box
Ammeter to main alternator terminal
BrownYellowAlternator to 'no charge' warning light
BrownBlackAlternator battery sensing lead
BrownSlateStarter relay contact to starter solenoid
BrownOrangeFuel shut-off (diesel stop)
MAIN TRACER PURPOSE
Green Accessories fuesed via ignition switch
GreenBrownSwitch to reverse lamp
GreeBlueWater temperature gauge to temperature unit
GreenRedDirection indicator switch to left-hand flasher lamps
GreenPurpleStop lamp switch to stop lamps, or stop lamp switch to lamp failure unit
GreenLight greenHazard flasher unit to hazard pilot lamp or lamp failure unit to stop lamp bulbs
GreenWhiteDirection indicator switch to right hand flasher lamps
GreenYellowHeater motor to switch single speed (or to 'slow' on tow- or three-speed motor)
GreenBlackFuel gauge to fuel tank unit or changeover switch or voltage stabilizer to tank units
GreenPinkFuse to flasher unit
GreenSlatea)Heater motor to switch ('fast' on two- or three-speed motor)
b)Coolant level unit to warning light
GreenOrangeLow fuel level switch to warning light
MAIN TRACER PURPOSE
Light green Instrument voltage stabilizer to instruments
Light greenBrownFlasher switch to flasher unit
Light greenBluea)Flasher switch to left-hand flasher warning light
b)Coolant level sensor to control unit
c)Test switch to coolan level control unit
Light greenRedFuel tank changeover switch to right-hand tank unit or entry and exit door closed switch to door actuator
Light greenPurpleFlasher unit to flasher warning light
Light greenGreenStart inhibitor relay to change speed switch; or switch to heater blower motor second speed on three-speed unit
Light greenWhiteLow air pressure switch to buzzer and warning light
Light greenYellowFlasher switch to right-hand warning light; or differential lock switch to differential lock warning light
Light greenBlackFront screen jet switch to screen jet motor
Light greenSlateFuel tank changeover switch to left-hand tank unit; or entry and exit door open switch to door actuator
Light greenOrangeRear window wash switch to wash pump; or cab lock-down switch to warning light
