It is currently Tue Aug 12, 2025 1:19 pm
PostPosted: Thu Aug 05, 2010 10:01 pm
NAV-MAN
GT mowog wrote:
NAV wrote:
justminis wrote:
GT mowog wrote:
I prefer to take the drive shaft out of the pot joints rather than seperate the pot joint itself. It is a little more difficult to remove, but is far cleaner and does make it much easier to put back in :wink:
+1. Only way to fly :D
Don't for get to drain the oil first,
Pot Joints actually stay on the Gearbox, the driveshafts get 'disconnected' from the pot joints, so you can leave the oil in if you want :wink:
I read that completely wrong. I usually pull the shaft out of the pots as well
PostPosted: Thu Aug 05, 2010 10:25 pm
flamingdrongo wrote:
I am in the midst of an engine swap and I can't get the pin out of the gear selector on the rod change. Granted, I'm trying to use a bolt to bash it out, but it's a pain in the.... I'm going to get some pin punches tomorrow but am anticipating that there won't be enough room to swing a hammer on it. I've snapped a drill bit trying to drill it out. I've had one fall out on me whilst driving, but when I actually want it out it won't budge. What gives? Also, if it wasn't for this post, I would have absolutely forgotten about the speedo cable. I'll probably forget about it tomorrow after a few beers too :(
Put it in reverse gear first, then you can easily knock the front pin out. With a pin punch... :wink:
Users browsing this forum: Bing [Bot] and 261 guests
