It is currently Sun Aug 24, 2025 9:29 am
 Post subject: Bump Stops? Fixed!!
PostPosted: Sat Aug 21, 2010 4:29 pm
Fixed!! Bump stops installed, tyres no longer contact guards. :D :D :D
Thanks Guys
Now I'm thinking maybe I could get away with it being a little lower. Is there a safe/easy way to let out some fluid without a Pump. I realise if I let it down too much I'll have to go get it pumped up again.
 Post subject: Re: Bump Stops? Fixed!!
PostPosted: Sat Aug 21, 2010 4:41 pm
Thanks Guys
Just take the metal cap off, turn it over, use its dimple to push the valve stem in, gently... :wink:
I do this often...
[edit] rock the car side to side after you do it before checking height.
PostPosted: Sat Aug 21, 2010 6:28 pm
Thanks Guys
I do this often...
whoops, let a little out, then a little more and it wouldn't stop. :shock:
Oh well, will get it pumped back up next week.
I was gentle. honest :oops:
PostPosted: Sat Aug 21, 2010 6:42 pm
phillb wrote:
Thanks Guys
I do this often...
This often happens. If the fluid has been in a while, there does seem to be rust in with it and the valves too get gummy and will easily stick open.
I'd suggest having your system evacuated (properly under vacuum) fit new schrader valves and then have it pumped up.
Lucky you've got them bump stops in eh?
PostPosted: Sat Aug 21, 2010 7:03 pm
GT mowog wrote:
phillb wrote:
Thanks Guys
I do this often...
Yes, things went from :D to :cry: Oh well.
Yes I'll do what you suggest. Good chance to get that done I guess.
I understand I can carefully drive it to the mechanic in this condition?
PostPosted: Sat Aug 21, 2010 7:40 pm
Yes, although it is not recommended to drive over 30 mph (50 kmh).
PostPosted: Mon Aug 23, 2010 5:49 pm
Got the Hydro pumped back up and the valves replaced. Had it adjusted slightly lower to a height suggested by the mechanic, seems to handle a little better now too.
:D :D
PostPosted: Mon Aug 23, 2010 10:34 pm
:D :D
that may be because your alignment is better, or worse :D
changing the height changes the toe and camber, so an alignment might be a good idea ;)
PostPosted: Mon Aug 23, 2010 10:36 pm
simon k wrote:
:D :D
Yep, I was thinking that, ....next on the to do list. :)
Users browsing this forum: No registered users and 293 guests
