blue_deluxe wrote:
The engine is irrelevant, its all in the gear ratios.
You want an engine that revs as high as possible that pushes the highest gear ratios and then the highest final drive with the biggest wheels.
Ahhhhhh,,, but this is not quite the case,,,
it`s all good in theory but just doesn`t happen in reallity
it`s all good & well getting a high reving engine,,, & it`s all good & well giving it really tall gears,,, but the poor little things just dont have the """"Power""" to pull tall gears
if you put a 3.4 f-d into an "S" ((((& lets make it a good "S" for arguments sake,,, lets make it a 1415cc stroker with piles of good gear inside)))) Now run it as hard as you can for as long as you can,,, lets even make it down hill...... yeah???
Now fit a 3.2 or a 3.1 f-d into it,,, i doubt it will make it much faster top speed, Maybe a tad,,, (Barely a tad if you`re lucky)
but now lets fit a 2.9 f-d into it,,, i """"""""guarantee""""""" it will not be as fast,,, it wont rev out & won`t have the power to push that tall a gear ratio
simple as that
BUT!!!!!!!!!!!!! if you (Magically) threw more power at it, then maybe it will make a tad more top speed,,, even a turbo or something will help it,,,, but it will "HEAPS" more to pull that tall a gear
the fact is,,, you need BIG """GRUNT""" to pull tall gears,,, without the GRUNT (& lots of it) you just won`t get there
Without the revs, ,, , , you just won`t get there
So,,,,, you need both power to pull the gearing to be able to get the revs,,, & of course the engine needs to be able to rev hard too yes,,, but it`s the Grunt "Coupled with" the abiltiy to rev with such a tall gear ratio to make it happen & minis just don`t have much GRUNT
Most minis on the planet (even good quality race minis) just don`t have enough GRUNT to get past 130mph
& most hot road minis will NOT get past 115mph
