My Minispares intake is shaped differently - big bore for 1380 (with Minispares big bore LCB). Spacer is absolutely required to actuate the HIF at all and even then careful machining of the spacer was needed to fit assembly to head with clearance for floatbowl. And then careful filing was needed to allow throttle cable clearance on the manifold.
Both intake and LCB went out for ceramic coating...after careful fitment on the bench to get flange/port matches. Even though both were from Minispares they would not even bolt up together without addressing interference and intake flange shape/thickness.
Intake has ceramic coating on exterior only. LCB inside and out. Latter reduces under bonnet temps by +100F.
QUESTIONS - Could quadrant be different? Activation by throttle cable different?
