Wombat wrote:
The Minimans method is to slacken the front adjusted (both) right off to bleed the cylinders - I also read an article on how to bleed brakes and they suggested to open the adjusters to max then with drums off use a couple of clamps to squeeze the brake shoes and so squeezing the air out off the wheel cylinders - bleed then release the shoes- replace the drums and adjust
You can do this with just the wheel cylinders on the car. As long as fluid is gravity feeding to the cylinders.
When you close the bleeder, the pistons in the cylinders will move out. Once they are out, open the bleeder and push the pistons back in, then do the bleeder up and watch the pistons move back out as they fill up again.
It works better when its just a single cylinder setup though.
