NAV wrote:
Irish Yobbo wrote:
But a bit of a balance is needed. If you have too small a bore in your MC, you'll have difficulty adjusting the brakes properly - there will be too much pedal travel.
I couldn't imagine there would be that much travel that the smaller rear cylinders I'm putting in would start working before the fronts do. And then there is the force limiting valve (which actually works in my car) to stop the rears locking up. Or is there something I'm missing here?
The smaller rear cylinders are to lower the braking power at the back. Discs actually need more hydraulic pressure than drums - if you don't change the rear cylinders, the back brakes will lock up before the front.
The limiting valve only restricts the pressure once you are braking hard. It's sort of like a cut-off valve, once the pressure reaches a certain level, the valve will stop it from going (much) higher. So this shouldn't change your pedal pressure. Is this the 5-way valve mounted on the bulkhead?
Just remember that fitting discs will NOT give you a lighter pedal - infact, it will do just the opposite! Because there is more braking surface on drums, the require less pressure, but since the surface is always in contact, they suffer badly from brake fade.
