It is currently Thu Aug 14, 2025 8:14 pm
Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Tue Jan 11, 2011 6:33 pm
Cooper, email replied to. :wink:
PostPosted: Tue Jan 11, 2011 6:40 pm
Thanks Doc.
PostPosted: Wed Jan 12, 2011 1:01 am
I have intsalled the rear brackets and will be putting on the front parts later this week. It's a pretty strait forward process. If you have any questions about it pm me
"if its got tits or tires it'll cost yah"
PostPosted: Thu Jan 13, 2011 8:32 am
Whipped this up for my attempt at a home made camber gauge. Good news to on postage. Full kit and a set of mats are on their way for only $212. Awesome.
PostPosted: Thu Jan 13, 2011 8:35 am
Was under the car up on the hoist with the zorst man this morning. I cant see where the rear camber brackets go. Does anyone have a pic/diagram of where I need to look? Again, apologies for the 'N00b'ness of the question!
PostPosted: Thu Jan 13, 2011 9:29 am
Hi,
Do you mind sharing the discount code for Minispares?? I am hoping to do an order this month as well.
Thanks
Minimad
You can take the boy out of the racer.........but not the racer out of the boy!
PostPosted: Thu Jan 13, 2011 9:37 am
CJANDISCOUNT gives 7.5%. It adds up!
PostPosted: Thu Jan 13, 2011 9:38 am
Thnaks :D
PostPosted: Thu Jan 13, 2011 10:11 am
Found it.
PostPosted: Thu Jan 13, 2011 3:09 pm
Surely the reason you but an adjustable front end is simply so that you can adjust it, or have it adjusted by professionals to suit your needs! A must in any type of motorsport.
Thanks for the nifty apps anyway.
H 8)
PostPosted: Thu Jan 13, 2011 3:23 pm
Correct Haydn, on all counts. I want to know what I'm adjusting and what happens so I can play/tune/fiddle/tweak.
PostPosted: Thu Jan 13, 2011 5:44 pm
Our first adjustable front lower arms were "home made" with spherical heim joints as were the rear adjustable trumpets and rear camber brackets (though the brackets are easy and reliable assuming you've got new or good used ones to modify). Geeez we got away with it all.
TIP #1 - don't buy anything less than aircraft grade heim joints.
Tip #2 - shield the spacers and heim joints with grease filled rubber hose.
Tip #3 - use simple garbage ties to locate your 2 up loading on adjustable rears so extending for full load can be easily done without remembering how many turns to count etc. It's simple and visual.
Later we bought the real thing but still had bronze spacers made up for the "wiggly pin" to locate the lower arm.
At the end of the day a laser alignment shop operated by a Mini man will get you close...only close, because there are so many variables like, how much will your mate riding in the offside seat weigh?
PostPosted: Thu Jan 13, 2011 5:48 pm
For the record...I set up my sedan to have "about" 1 deg. negative camber F/R. 3.5 deg. caster, standard toe out at front and zero toe at rear. This suits longer trips on major highways and gives useful grip on the twisties.
PostPosted: Thu Jan 13, 2011 6:02 pm
I was planning to buy the same kit but in the end I just ordered the front. Wish I had the rears as the front is now spot on - but needs some serious work on the rear arms.
I ordered the Minispares ones as pictured as these were recommended by a few Mini repairers over the Huddesfield type.
BTW - cost $60 to have set up at the local Pedders shop (who just happens to drive a 67 Deluxe!)
Dave K.
PostPosted: Thu Jan 13, 2011 7:21 pm
I've been told (not totally sure it's true) that fitting Heim/Rose joints is illegal for street use here in NSW.
Users browsing this forum: Bing [Bot], TartanRed and 142 guests
