It is currently Wed Aug 20, 2025 3:22 am
PostPosted: Tue Feb 01, 2011 3:18 pm
Supercharged
yeah i wind them in with a nut and washers
PostPosted: Tue Feb 01, 2011 8:52 pm
I cant believe it's still off the road, nothng some new studs and a hammer cant fix over a couple of beers
PostPosted: Tue Feb 01, 2011 9:54 pm
If you get the wheel off and can measure the length of the stud and bring it up to my place I am sure that I have plenty of studs to suit and will check the collection of wheel nuts.
I have a nut/puller arangement to pull the new studs in which you can borrow.
If the nuts are a odd ball size etc, I can knock up a couple for you.
Send me a PM if you want and will give you phone No's etc.
www.minisprintgt.com
PostPosted: Wed Feb 02, 2011 7:19 am
sgc wrote:
VicMini13 wrote:
Also said that it just had a set of disks fitted - probably the studs weren't pressed (pounded with FBH) all the way it. Check all the others.
I've never belted them all that hard when I've fitted mine. In fact, 9 times out of 10 I do it with the drive flange on the car, and just press them in with a set of vice grips, then tug them all the way onto the splines with a wheel nut and a few washers...
Still worth giving them a couple of taps while the nut is still pulled up tight. It only has to be a couple thou left to go and it can pull in the rest of the way on a couple of spirited corners and let the nut come lose.
PostPosted: Wed Feb 02, 2011 3:14 pm
On a trip to Hay once a mate broke three studs on two wheels. Diagnosis was he'd overtightened them and the heat generated on a long fast drive had caused them to break.
Blair Athol Auto Parts (Mini King) on Churchill Rd Kilburn are long established Mini parts/mechanical specialists (since 1960s). About 6 km north of the CBD.
In the City itself there's an independent Land Rover / Britpart specialist in Angas St called Sovereign Automotive - they do Rover cars as well as 4X4s so may do work on Minis if you ask nicely - it's a pretty straight forward job.
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Wed Feb 02, 2011 4:39 pm
Thanks for all your help guys.
I will give it a go pulling them off tonight and let you know how I go tomorrow.
Users browsing this forum: No registered users and 404 guests
