It is currently Mon Jul 28, 2025 6:27 am
PostPosted: Mon Mar 28, 2011 4:01 pm
This space for rent
I'm sure it's been mentioned, but if you're fitting any 1275 engine to a Mini you must fit disc brakes for it to be legally road-registered. All 1275 Mini's built or sold new here were fitted with discs, so you've gotta have them if you retrofit a 1275.
PostPosted: Mon Mar 28, 2011 4:07 pm
Ryan1980 wrote:
also, how bad are the drum brakes? If there in good condition and adjusted etc, would that be ok? Or still too dangerous?
Brand new drums running a vaccum booster are aparrently very good. But anything less than brand new and adjusted fortnightly is bad (for a fast mini)
PostPosted: Mon Mar 28, 2011 4:53 pm
ok well clearly i will have to look at upgrading to discs, especially if i get the 1275.
So if my thumb fits between the rocker cover and thermostat housing its a 1275?
When talking about a 1275 mini, its not a debate about the virtues or short comings of drum brakes.
Its a legal requirement.
That cant be said any clearer. If your not prepared to fit discs then dont buy the 1275 or fit a 1275 into a mini with drums.
Some 1275 mokes have drum brakes because of a precedant set by BL in its dying days when they were using up existing stock.
No 1275 mini sedans were ever factory fitted with drums. If you were ever in an accident that involved injuries and the investigators twigged it was a 1275 with drums you could lose all insurance cover and could be left with a compensation claim by the injured that reaches hundreds of thousands.
Mike
PostPosted: Mon Mar 28, 2011 5:38 pm
ok no problem, if i buy it i will fit discs.
what im more concerned with right now is how to determine that it is what the owner says it is ( a 1275)
PostPosted: Mon Mar 28, 2011 5:50 pm
Going off the head is not always reliable, it could be an 1100 with a 1275 head, a moderately popular modification.
Get the Engine Number and if you can, have a look down the back of the engine (behind and under the manifolds) for removable tappet covers and provision for (or could be fitted) a mechanical fuel pump. No tappet covers = 1275. If it has tappet covers it could be 1100 or 1275.
Generally, 1275 Engines will have a 12H, 1200, 1204, 1207, 12G, 12Y, 12YA, 12YD prefix but there are also others.
1100's on the other hand generally start with 10*** or 1001.
PostPosted: Mon Mar 28, 2011 5:51 pm
dont 1275 's block s start with 12 on em. first 2 numbers.
PostPosted: Mon Mar 28, 2011 5:59 pm
No - some are 9SAY etc - they are the true cooper S bocks.
PostPosted: Mon Mar 28, 2011 6:40 pm
Mk1 S = 9F/Sa/Y
Mk2 S = 9F XEY
PostPosted: Mon Mar 28, 2011 7:02 pm
Oops left of a character - Doc is right. Moral - never type and hit submit while wife is talking to you about another domestic issue
Sorry
Mike
