It is currently Sat Aug 02, 2025 5:54 pm
PostPosted: Fri Apr 08, 2011 8:38 pm
simon k wrote:
honestly, you're not going to get any useful help from here - there are just too many things that could be wrong, anyone would just be guessing.
Unplug everything, just start with the basics and make each thing work, one thing at a time.
If you can't work it out, then you'll just need to take it to an auto-elec or get someone to come and help you
I agree with Simon, unplug and bit by bit re connect.
The next step perhaps would be removing the entire harness, unwrapping it and carefully inspecting it for damage. You never know what damage may have occurred during all these problems (eg wires melting together)
Mine looked fine until I unwrapped it and found whole sections of wire exposed and melted together. Some looked like it had happened years ago.
PostPosted: Fri Apr 08, 2011 9:58 pm
have to agree, disconnect everything. Start with the Fuse Box and keep the Brown wires connected and the opposition side You should be able to start the engine & use the Horn With Fuse Two has the White connected. Refit each plug and each time check what works and does not or effects the other
 Post subject: Or
PostPosted: Sat Apr 09, 2011 6:01 am
Take it to someone who know what they are looking at and stop wasting your money on guess resolutions. It will be cheaper in the end.
We Charge
$80.00 per hour.
$100.00 if you watch.
$140 if you help
and
$160 if you have already attempted to fix it yourself.
Pricing is also subject to change according to customer’s attitude
( Let us remove your shorts)
"Let us remove your "SHORTS"
PostPosted: Sat Apr 09, 2011 4:00 pm
... Headlight switch was wired back to front...
I am an idiot
