It is currently Sat Aug 23, 2025 9:00 pm
PostPosted: Sun Jun 19, 2011 2:05 pm
I'm told GR always uses heat to get the flywheels off.
smac wrote:
All this talk of wheels flying off.... length of chain between a couple of the housing bolts fixes that.
good plan
I have an ultra-long flywheel bolt, apparently from an early 850 - when fully screwed into the end of the crank it still has 3/8" clearance. I do my puller up against that, and when the flywheel pops off, it can't go anywhere :)
PostPosted: Sun Jun 19, 2011 2:22 pm
good plan
I do that too Simon.
Oh and you also need to heat up the Loctite thread locker on the flywheel bolt, so you are in there heating anyway. May as well leave it hot and pull the flywheel off while it is still hot.
michael
PostPosted: Sun Jun 19, 2011 2:33 pm
I've seen 2 different types of those hydraulics pullers like the original post and GT mowogs. Both the same design but the ends differ. One of the pullers requires the cap to be fitted into the crank, the other pullers end is already designed to fit the end of the crank.
And it's quite common if you just have the engine on the ground, for the flywheel to travel a metre or more if its a tight one, so as everyone says, dont stand in its way.
PostPosted: Sun Jun 19, 2011 5:23 pm
MrFail wrote:
oh, so no bolts off the engine/ clutch will be right for it???
Aren't cylinder head studs the right thread? From memory that's what I use.
PostPosted: Sun Jun 19, 2011 6:23 pm
Heres a link to a good puller, it is also based on grease hydrolics like the coxhead puller.
Its on the to make list when I buy a lathe
I also have a coxhead puller its got every flywheel off to date.
http://www.drjing.com/Mini/TechFiles/Hy ... Puller.htm
PostPosted: Sun Jun 19, 2011 7:29 pm
yep, but you need some 3/8 UNC nuts for the other end
PostPosted: Sun Jun 19, 2011 7:43 pm
I'd just go buy 3 HT 3/8 UNF bolts the right length. Grade 8 hex bolts work fine but Grade 10 or 12 cap head ones are stronger.
Make something to sit in the end of the crank so you don't bugger it- I use a 1" long 5/8" bolt with the threads machined off.
Users browsing this forum: Bing [Bot], jpodge and 73 guests
