It is currently Sun Aug 03, 2025 2:48 pm
PostPosted: Tue Sep 20, 2011 11:29 pm
danny_ wrote:
Anyone in sydney have a code reader i can borrow to re-set mine?
Mine is running very very rich.
I can smell fuel in the cockpit when shifting from 1-3 (its an automatic SPi)
It never used to do this.
Give John at MiniKing a bell.
He'll give you a number for a machine shop that has one.
The joints not far from his shop, a few k's.
It will cost you $$$ for them to do the job though.
Image Image
PostPosted: Tue Sep 20, 2011 11:35 pm
That minispares number doesnt exist?!?
PostPosted: Wed Sep 21, 2011 8:59 am
Online
Sure, it does... :P you just won't have an SPI any more...!
http://www.minispares.com/Product.aspx? ... 499&title=
ROFL
PostPosted: Wed Sep 21, 2011 7:33 pm
danny_ wrote:
My LHM must be broken.
My crank shaft sensor died and needed replacing.
It took the guy 8 hours to test everything and find the problem.
That is the only sensor that can not be bypassed as that is only sensor that knows when to fire the plugs.
Cheers Pete
PostPosted: Wed Sep 21, 2011 7:53 pm
I don't profess to be anything like an expert here but I've had a bit to do with vehicles with EFI. Normally on an old system, say you disconnect the airflow sensor or coolant temp sensor, it'll just stop. On newer cars, you do the same thing, the motor keeps going, maybe not as good, and on comes the check light. You take it to your dealer/workshop, they scan it and that'll indicate the fault.
My car was running poor, not totally undrivable, so upon noticing the temp guage reading cold, I thought the thermostat might be stuck open, not the case, the engine temp was around 85-90 by my temp gun. Next I thought, temp sender unit for guage. So after not finding it in any normal place, I checked the w/shop manual/wiring diagram. Same unit does both, so I though I'd disconnect it to see if it would alter the running by going into a LHM, this didn't happen, it started running super rich to the point the even holding the throttle on it just smoked to a halt.
Fast forward a week. Got a new sender unit and after much cursing of the dick brain who decided to put it in the dumbest place ever, got it fitted and it runs fine now. That's how I concluded there wasn't a LHM on my car, cause it didn't limp home, it just turned up it's heels and played dead. :(
Users browsing this forum: Bing [Bot], drmini in aust and 97 guests
