Kurross wrote:
Awesome, thanks for providing the diagram and describing clip points!
Sorry just one more confirmation, so the only points the lines are attached (to body or frame) is the inside rail of the subframe, at the connection with rubber hose? Is it attached to the firewall in anyway at the three way connector?
Thanks again, (I owe many of you guys a beer or two, if you’re ever in the Shellharbour area)
Mark
Sorry, the pipe that runs front to rear, under the floor, is also 'clipped' in but in this case it is tabs that are welded to the body that are folded over it. There is also one up the font toe board on the body just below the top of the rear rail, just out of sight in fact.
Also, there is another single welded 'clip' in the front rail of the rear subframe, just to the left of the middle of it.
All other pipes are 'floating' ie, not clipped in, only held in place by the tube nuts on the ends.
There's also some info here if you're thinking of making any pipes;-
http://www.ausmini.com/forums/viewtopic ... rake+pipes
And, your most welcome
