It is currently Sat Aug 02, 2025 3:24 pm
PostPosted: Wed Jan 15, 2014 10:28 pm
Yeah, it will work.
Max chickens on that gauge is 58 PSI (@400Kpa). It would work fine, but the needle would spend most of its day at max deflection.
I'm guessing perhaps its a standard smiths oil pressure gauge with 100 KPAs screen printed instead of PSI.
PostPosted: Thu Jan 16, 2014 6:51 am
Ok. So what type of sender does it nneed.does it need to be specifically designed to work with smiths gauges?
Dusk Blue
1964 850
PostPosted: Thu Jan 16, 2014 7:01 am
You would probably have to measure the resistance across the gauge.
Also I seem to recall having a smiths electric gauge in my old mini that the VDO sender seemed to give odd (low) Oil pressure readings. I replaced it with a genuine smiths sender (exxy) and all was good.
With the right senders in place, I never had any trouble with electric oil or temp gauges. I run electric gauges in other (non-mini) cars I own with no issues.
PostPosted: Thu Jan 16, 2014 7:48 am
It looked like a capillary gauge to me...?
PostPosted: Thu Jan 16, 2014 8:50 am
The capillary tube for a mech. oil gauge should be pretty cheap? (Cheaper than getting a new elec sender?) It's just a tube with the locking nuts on them.
http://www.getcarbitz.com.au/speco-pres ... 88173.html
http://www.garage7.com.au/home/index.ph ... &Itemid=53
PostPosted: Thu Jan 16, 2014 10:26 am
Yea, its an electric one . If I cant find a suitable sender cheap, I will just get a new pipe for my mechalical one. I just thought it might be a little simpler if I could just put in an electric gauge.
Dusk Blue
1964 850
