It is currently Fri Jul 18, 2025 4:08 pm
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Mon Jan 16, 2012 7:01 pm
I think that Dunlop only made wheels in the UK. I have not seen anything saying they made wheels anywhere else.
All Cooper S wheels were imported- I bought a new set in 1966. :wink:
ROH made the 3.5Bx10 Mini wheels here, but their well diameter was about 1/8" bigger than the 4.5Jx10 Cooper S wheel.
Way back then I used to widen S wheels for Parramatta Speed Shop. I used a 3.50Bx10 outer rim, split it and rolled the well diameter down to fit.
Then stick welded it to the split S rim, so it had 2x wide beads. Could get to 6" wide, just.
PostPosted: Mon Jan 16, 2012 7:14 pm
These wheels look great! does anyone know if 4 pot alloy minispares calipers would fit behind then without using spacers?
Richard.
PostPosted: Mon Jan 16, 2012 7:22 pm
Okey dokey. Thanks Simon and Morris. Am off to get some weekend wheels.
Will post fotos. .....Promise.
PostPosted: Mon Jan 16, 2012 7:24 pm
Richard.
they don't... SGC and I tried them on his car (non-vented minispares 4 pots), and it came close, but no dice
PostPosted: Mon Jan 16, 2012 7:25 pm
if you get the ones from minisport, I'm keen to see the casting numbers etc. inside them
PostPosted: Mon Jan 16, 2012 8:26 pm
Np, will do. Note that shipping = with a beez dik, cost of wheels :shock:
PostPosted: Tue Jan 17, 2012 9:45 am
Richard.
I've got tarox 4pots on a rover (vented with 8.4" drive flange) - the calipers a smaller than the minispares ones by the looks of it - they are tiny.
Interested in these wheels, if i tried a standard S steelie would i be able to check the clearance? are they the same?
PostPosted: Tue Jan 17, 2012 10:51 am
S steel wheels are smaller inside than the alloys - so if an S steelie fits then these will... and I'll start saving up for a set
tarox have dimensions here, I'll put modelling a caliper on my list of things to do, I modelled the wheel a few years ago (or is Em busy??)
http://en.tarox.com/products/racing-brake-calipers.html
PostPosted: Sun Feb 26, 2012 4:56 pm
Hey 'Morris', are they normal S's hubcaps? I would like to put caps over my new alloys.
PostPosted: Sun Feb 26, 2012 4:57 pm
you mean "Hey Simon", right??
I'm not telling you if they're normal hubcaps until I see a picture of the inside of the wheel :P
PostPosted: Sun Feb 26, 2012 5:49 pm
Me nutz.
[/code]
 Post subject: Now mit pics
PostPosted: Tue Feb 28, 2012 5:17 pm
That should shut him up!
PostPosted: Tue Feb 28, 2012 8:28 pm
thanks Bam :)
here's the inside of mine - quite different - I reckon it's a different manufacturer. And I've figured out what 104535 means
PostPosted: Wed Feb 29, 2012 6:32 am
[quote="simon k"]thanks Bam :)
How do you keep a fool in suspense?
I'll tell you later.........
OK, I'll bite, what does '104535' mean?
PostPosted: Wed Feb 29, 2012 9:16 am
How about 10 X 4.5" with +35 offset?
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
