It is currently Wed Aug 20, 2025 8:31 pm
PostPosted: Sun Jun 16, 2013 6:38 pm
The Mini King
PM Sent
PostPosted: Thu Nov 28, 2013 6:43 pm
Has anyone else spent ages having an absolute c*** of a time trying to get the drive back in?
Im sure Im at TDC on #1, when I am I cant for the life of me get it to thread.
When I rotate the crank out of the way slightly it slips in fine but I'm no longer on TDC
PostPosted: Thu Nov 28, 2013 8:37 pm
Threads like this are great and get saved in my mini folder for later reference simple and easy to use tips.
PostPosted: Thu Nov 28, 2013 9:05 pm
You don't need to put the drive in on TDC. Put the drive in where the crank is convenient, and then roll the crank back to TDC to check your position. If it is not right, repeat the process, but rotate the drive before putting it back in so it lines up better next time you put it back to TDC. Just do that a couple of times and you will get the setting you are after.
PostPosted: Fri Nov 29, 2013 4:02 pm
Its amazing what coming back to a problem later will solve.
Worked it out rotating the engine back ad forth for a while.
Cheers fellas
PostPosted: Sat Nov 30, 2013 3:53 pm
Right so this is really doing my head in.
Distributor shaft is set to 1 o'clock at TDC, distributor is in with rotor pointing to 1, I have spark have fuel but still can't get the bugger to run.
I'm getting big backfires out the carb.
I have tried advancing the timing, I have tried the mixture screw on the carb.
Could the timing be 180 out? Surely not. After all this.
Is it possible I was at TDC on the wrong stroke?
PostPosted: Sat Nov 30, 2013 5:01 pm
Sounds like you are 360degrees of the crank out (180 at the dizzy)
When you are using the manual to build your engine, you time the camshaft in with no.4 cylinder firing. The image showing the positioning of the distributor drive is for no.1 cylinder firing.
You can either put the shaft in the correct spot, or just change your spark plug leads around.
PostPosted: Sat Nov 30, 2013 5:56 pm
Does the lead order get reversed then?
PostPosted: Sat Nov 30, 2013 7:25 pm
just shift them all around 2 positions
Users browsing this forum: phillb and 302 guests
